Question about Sony Handycam DCR-DVD201 DVD Camcorder
Sony Handycam dvd201 and iMac G5
Does anyone know if there is anyway I can get the raw footage from my Sony Handycam DVD21 onto my imac G5. the camcorder does not have a Firewire connection nor is the USB connection recognized by the iMac. I also cannot load ImageMixer (Sony software) because it will only work on a PC platform. Any suggestion would be most appreciated!!
    Master:
  • 473 Answers
Looks like a rip operation. Close the DVD session and try http://www.macupdate.com/info.php/id/14414
Posted on Sep 14, 2005
SOURCE:
I can't find my dcr hc21 when trying to download video to my imac
Use a firewire cable to connect not USB.iMovie should be on your Mac and will capture and edit the footage.
Al
Dec 26, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
G5 keeps powering up for a few mins then switches off?
Thank you for contacting Fixya Support, I am glad to assist.
There are a few steps you can try to troubleshoot this issue:
Try a PMU Reset:
* Turn of your iMac if it is already turned off
* Disconnect all connections to the iMac except the power cord
* Now disconnect the power cord for approximately 20 seconds
* Reconnect just the power cable the keyboard, mouse and power cord, and then power your iMac G5 up.
* Check to see if the iMac boots up normally without power interruption.
* If the iMac G5 shuts off again, try these steps, another recommendation would be to remove all connections including the power cord, and lay the iMac G5 on soft cloth face down and with a philips screwdriver, remove the plate on the bottom of the iMac G5 where your RAM memory is located.
Before removing the RAM however, touch your hand on the metal boot to discharge any static current you carry for approximately 5 seconds.
Now remove each RAM card and then reseat (re-install) each card.
Restore the RAM card cover with your Philips screwdriver, reconnect your power cable, keyboard an
d mouse and turn on your iMac G5.
See if this second procedure helps if the first procedure does not work.
Let me know if this helps.
Regards
-Mactechtrainer
Sep 11, 2010 | Apple iMac G5 Desktop
IMac OSX 10.4.1 doesnt recognize SONY handycam format
you would need to update by doing a software update ( apple at the top left --> software update ) update everything until you are at 10.4.11 and also update any other software it prompts you to - if you have an older version of quicktime with a serial key make sure you know what the serial key is as the later versions of quicktime will over write the older ones.
you can get perian which should help you with regards to video codecs :
Perian website
You can also download and install the divx and xvid codecs from these sites
divx here
xvid here
Also try VLC :
website here
If none of the above works then what file formats are the video footage clips and did you get any software with your cam to work on the mac if not then you should be able to use iMovie and or iDVD to help you with the video side of it.
Apr 28, 2009 | Sony Handycam Camcorder
Can't seem to transfer footage from my SONY HDR SR10 to my imac
I don't know if you would call this a solution but I do know that some computers or programs will not except certain cameras. For instance I have a Sony computer and the editing program I have is Adobe Premier which will not except footage from my JVC camera but will except the footage through my Canon camera. I think the Eggheads that design these programs just like to screw with people.
Mar 31, 2009 | Sony HDR-SR10E HDD Camcorder
Sony handicam
I don't think you can use the unit for individual snapshots but you can take short segments of video then, download to your computer. After you have loaded segments of footage, you can then take individual snapshots from the footage. In a way this is better as you can select from many angles, positions ect.
Jul 13, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
IMac G5
you need to contact apple support for the same
Jun 23, 2008 | Apple iMac G5 Desktop
Airport Extreme 802.11g
At this point you are much better off installing a USB wireless antennae than spending money on an Airport card, cracking open the iMac, and installing it.
USB wireless adapters are cheap, plentiful, and have more capabilities than the generation of Airport cards that were made for G5 iMacs.
Apr 14, 2008 | Apple iMac G5 Desktop
New iMac and 2000 Sony Handycam DCR-TRV330
iMovie should support any Digital camcorder that hooks up with Firewire (IEEE1394)
Feb 13, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony Handycam DCR-DVD201 DVD Camcorder Logo
207 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
