Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Saeco primea Ring
I have problem reading instruction what I need is a DVD orCD.Can you help me? thank you.
  • 515 Answers
What i know there will not be any dvd or cd, it´s only on paper:-(
/Mirran
Posted on Sep 03, 2008
Hi, I have the Saeco Primea Cappucino Touch Plus , and it syddenly gives the error code 5 - Call assistance. I have just changed the primea Water Filter - same way as always ! What can I do ?
Need to prime the machine. The new water filter is causing the air lock in the system.Remove the filter and startup the machine it should prime by itself, when it's ready,fit the filter back and press hot water until the water flows steady. Hope it helps.
Sep 05, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Primea ring hot milk
Remember that the milk temp should be around 60-70c. Milk will start to boil around 80c.
You´re welcome and good luck!
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
if you go in the menu there a temperature setting for that machine pierre
Saeco Primea Ring stuck on warming up
Hi
I had the same problem and could solve it but i had take the machine apart.
Under boiler you have 2 thermo fuses that can be resetted. After reset i have checked if boiler get 220volt, It did for a short while but the fuses goes off again.
That means boiler is ok, it gets hot but fuses goes of due to temperature reach over 170 degrees celcius. That means that the power is olways on to the heater and doesnt stop to heat.
In diagnostic i could see that the temperature sensor does show the high temperature. That means that temp. sensor is ok which leads to the controller of the power to boiler. On the board i found big heatsink and a triac atached to it. I soldered it out and measure that it was spoiled.
Ordered new one for 3 euro. Soldered new one on the board and the problem was solved.
Original was BTA16-700CW but they didnt have it so i replaced it with BTA16-600CW, difference is that original one can handle 700volt the new one 600, but there is only 220volt it will controll anyway so that was ok.
I atach a picture.
Regards, Pawel
Nov 18, 2008 | Saeco Vienna Espresso Machine
Saeco Primea Cappuccino brewing very slowly
Try to descale the machine.
Try to adjust the grinder little.
/Mirran
Aug 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea RIng - Cycle interrupted - only a few drops come out
Hi
Have you found a solution yet?....we have the exact same problem....
Mar 16, 2008 | Kitchen Ranges
Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
143 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
