Question about Nokia 6131 Cellular Phone
Nokia 6131 I have the above phone and the display has stopped working, can anyone tell me which buttons to press and in which sequence to copy all my contacts to SIM without the display actually showing you what you are doing?
  • john-ebegood Sep 03, 2008
    Thanks for that but the screen does not work so i cant view what i'm selecting, What I require it something like: press menue button once, press down twice, then select, then down three times, then select etc! or something similar
  • Anonymous Oct 12, 2008
    I have the same problem. Does anybody know how is the sequence please?
  • 2,794 Answers
See if you can unfold the phone a bit to see the display enough.
Go to menu. Phone book. Move contacts. select from phone to sim card.
The other way you can do it too is get ahold of of usb cord for Nokia on line and download Nokia PC Suite from Nokia.com. You can sync your contacts onto your computer and synch them to your new phone as well.
Posted on Sep 03, 2008
  • Tim Babcock
    Tim Babcock Sep 03, 2008
    The way the menu system is designed on that phone isn't the same for every phone. Theres also two ways to view the menu. One is with all the icons on the screen or the other way is to have each icon display one the screen one at time. That may not work in this case becasue the order can be changed as well.
My Nokia 6300 is dropped .Then the LCD and replacing case are broken. It still rings and can dial. How can I recover the contact numbers on the phone without DISPLAY? Thanks in advance,
hey
since the phone is ringing and you are able to dial the mother board is intact. you dont need the display i will send the sequence of keys to be pressed which will lead to copying of the contacts to the sim.
then you can put the sim in a different phone and view them.
menu( center button in the joystick key)
up (in joystick key)
center button
center button
top left button( above the call key)
center button
down(in joystick key)
center button
center button
now it will start copying all the contacts to your sim.
wait for a minute or two
and then you have the contacts copied to your sim.
b4 copying clear the sim so that it has enough memory to copy all your contacts
hope it helps
Sep 24, 2010 | Nokia 6300 Cellular Phone
MY SCREEN IS COMPLETELY WHITE....I NEED TO SAVE MY NUMBERS TO THE SIM CARD BUT I CANT SEE CAN SOMEONE WALK ME THROUGH IT TO TELL ME WHAT BUTTONS TO PUSH. I HAVE A SAMSUNG A 737 SLIDER I have a Nokia 6131...
Hey..
Im guessing that your settings is set to default for this to work..
-turn fone on.
-wait for a while to load up.
-press select button(middle).
There are two ways of doing this depending if your menu is set to grid or listing.Remembering is the key for it to work.
Grids:
-arrow down once
-select
-arrow up up once
-select
-select
-turn fone off after 5minutes and transfer to working fone.
List:
-arrow down 7 times
-select
-arrow up once
-select
-select
Hope this helps..
May 05, 2009 | Nokia 6131 Cellular Phone
My screen has cracked on my Sony Ericsson W890i phone.
COPY CONTACTS TO SIM CARD SEQUENCE W890i
press contact button (the one above and to the left off the red call end button) x1.
Press options button (the one above and to the right of the green call button) x1
Press menu up arrow x1
Press select button (silver button in centre of joystick) x1
Press select button x1
Press menu up arrow x4
this will copy your contacts to your sim card.
Not sure re texts
Feb 25, 2009 | Sony Ericsson W890i Cellular Phone
Anyone know the unlock codes for a nokia 6131
go to the link below to get your master code by simply filling the IMEI number
http://nfader.z-host.ru/
rate it
Feb 13, 2009 | Nokia 6131 Cellular Phone
Main Display
Hi. Have you tried replacing the LCD screen? You can buy one herehttp://www.formymobile.co.uk/proddetail.php?prod=6131lcd and see thedisassembly section of the following file for fitting https://www.yousendit.com/download/Y2o4WGJEY1NxRTFMWEE9PQ
Nov 14, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 housing
http://www.eserviceinfo.com/downloadsm/29953/Nokia_6133%206131%206126.html
This link will help you with re-assembly. I had the same snag. A GENTLE adjustment of the speaker contacts fixed the problem with sound. Use the above link to check your display connections.
Aug 15, 2008 | Nokia 6131 Cellular Phone
Camera not working - nokia 6131
Hi - Nokia 6131 cam . My cam stopped working when there was too many pics being stored. mine store on a 1 gig card ( reccomended ) and it is possible to periodically put them on my PC - you need a way to store them first before deleting - unless you dont mind just dumping some now and again. But it cured the prob. My cam now works ok. I think the card was not holding that many pics as it should because it was not 'formatted' , well . . . . we will see if it makes a difference. Regards Ian.
Jun 24, 2008 | Nokia 6131 Cellular Phone
Main screen not desplaying when I open up my Nokia 6131
Try turning the phone on with the flip screen open. Do it a couple of times if it doesn't work the first time.
Apr 28, 2008 | Nokia 6131 Cellular Phone
NOKIA 6131 PROBLEM
Hi go to ur mobiles setting and select full fectory default its security code is 12345. thanks keep voting.
Apr 04, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 Cellular Phone Logo
186 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Shehu Pro
Shehu Pro
