Question about Sony Cyber-shot DSC-T20 Digital Camera
Vibration of T20
My T20 is only a few months old ,whenever i open the lens cover ,it starts vibrating and gets very blurred images.How can i solve this prob? Is there any free service offered by Sony.I bought the same from India.Hope u will help me to fix it soon.
Serial number?
Posted on Sep 12, 2008
My Sony dsc-t200 camera vibrates (I've droped it months earlier), pictures get blurred.
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Nov 04, 2009 | Sony Cyber-shot® DSC-T200 Digital Camera
My Sony camera vibrates when switched on and will not take pictures anymore. It is a cyber-shot DSC-T20
There is a known issue (vibration) with the DSC-T20 Cameras.
DSC-T20 Cyber-shot Camera Vibration:
Check this link for more information and get it serviced to resolve the issue.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT20&news_id=269
Good Luck!!!!!!!!!!
Oct 25, 2009 | Sony Cybershot DSC-T200 Digital Camera
Vibration after turning on
Make sure that the Battery is fully charged.
Check for the following steps:
  • Use the flash if the amount of light is insufficient.
  • Hold the camera steady with both hands
  • If the camera has an anti-blur feature, turn it on.
Please reset the Camera by selecting Initialize under Settings and Setup 1 Menu.
If the issue persists, your camera may require service.
Sep 21, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Vibration in camera and image when camera is started.
Bad antishaking mechanism inside of the lens assembly. Not solved by user.
Sep 16, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
DSC-T20 Sony Cyber Shot Camera that vibrates like a cell pohne. The vibration does not allow for a good picture it all. Could it that the anti vibration system of the camera goes into a full mode trying to...
Hi!
The problem you have is a faulty image stabilizer. It's a well known problem in these cameras. It's a hardware fault and I'm afraid you won't be able to fix it yourself. Usualy it requires the lens unit to be replaced. You should contact your local Sony service center or me at toms.safranovs@gmail.com - I give the best prices. ;)
I work in a Sony service center.
Hope this helps!
Tom
Jul 29, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
T20 Vibration problem
i have the same problem with my t20. i spoke to a sony shop in the uk and they said it was the motion sensor. it should be able to be done under warranty but youll need to go back to where you bought it.
Apr 22, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Vibration when using the Sony Cyber-Shot dsc-t20
Well, it seems that this is either a manufacturing defect or a defective/sub-standard part being used in the product. It would do Sony well to address this problem immediately so that all of us Sony lovers would continue to believe in their products. If this can be solved via a firmware upgrade then I hope Sony can guide us through it.
Feb 22, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Sony t20 vibration problem
Sounds like the T20 lens mechanism problem. Certain serial numbers for overseas cameras are also recalled so check with that countries Sony website.
Dec 26, 2007 | Sony Cyber-shot DSC-T20 Digital Camera
Vibration problem
Sony has recently discovered that with certain units of its "Cyber-shot" DSC-T20 digital still camera, a symptom may arise in which the camera body may vibrate when it is powered on, due to a mechanical failure affecting the lens, and it prevents the camera user from being able to shoot.
To ensure customer satisfaction, Sony will provide a free repair service when this symptom occurs within certain units covered by the serial numbers indicated in the serial number validation box below.
We apologise for any inconvenience this may cause. Your understanding and cooperation would be much appreciated.
Symptom and cause
The camera body may vibrate when powered on, due to a mechanical failure affecting the lens. This prevents the camera user from being able to shoot.
Applicable model
Digital Still Camera "Cyber-shot" DSC-T20.
How to check the model name and serial number
The model name and serial number are indicated on a sticker located at the bottom of the camera.
Applicable serial number
To determine whether your DSC-T20 camera purchased in Asia Pacific region may be affected, click here to validate the serial number.
Model Name Area Serial No. Range Unit DSC-T20/B AU2 2257001 - 2501900 5,050 DSC-T20/P AU2 2258851 - 2485700 4,700 DSC-T20/S AU2 2261851 - 2501500 7,650 DSC-T20/W AU2 2265751 - 2502100 7,650Period of free repair service
From 17th July 2008 to 16th July 2011.
PLEASE NOTE these serial numbers are applicable to ASIA / PACIFIC check your own country sony website if your serial number is applicable as different regions will have different serial number for the DTS -T20, hope this helps
Dec 24, 2007 | Sony Cyber-shot DSC-T20 Digital Camera
Sony Cyber-shot  DSC-T20 Digital Camera Logo
165 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
