Question about Casio (41644) 2.3 in. Handheld Television
Casio hand held t.v.
Model #tv-995b , will this model work after feb. 2009? this is what we use for hurricane info when electrick goes out.
thank you,
miriam pizarro
  • Anonymous Nov 09, 2008
    I have the same problem. And question the use of any battery power portable TVs after Feb 2009.
5 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: hand held casio tv vs digital signal
one BIG issue , like everything else that uses an ANTENNA ,will be obsolete , unless the manufacturers come out with a solution to this . hope this helps
Posted on Apr 30, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Hand held casio televisions
Even though it's small, it's still a TV with a standard tuner. So you could use it with a converter box if you really wanted to. You would need to connect the box to the TV's external antenna connector with an appropriate adapter. Then the TV would stay on channel 3 (or 4) while you change channels through the converter box. But just like any other set without the new tuner, once the regular broadcasting ends it won't be able to pick up digital channels.
Posted on Nov 10, 2008
  • 5 Answers
SOURCE: are there converters 4 hand held casio 880B
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Posted on Jun 20, 2009
SOURCE: Feb 17, 2009 - how can I use casio tv-900?
I just tried mine and i have no signal on the vhf setting but i do get channels on the uhf
Posted on Dec 20, 2009
  • 136 Answers
SOURCE: I can't get my CASIO model TV 995B open to replace
hold the tv with the front facing the top; then under the tuning buttons you should be able to push and slide down the bottom of the tv.. if i had a bigger picture of what yours look like then i could help more. or even go to casio.com and get manual for it.
Posted on Mar 14, 2010
Why wont my casio tv 600 pick up eney channels
I HAVE THE SAME PROBLEM BUT LAST NIGHT I PLACED THE TV NEAR THE FREEVIEW BOX AND THE TV JUST PICKED UP THE SIGNAL.A DIGITAL CHANNEL AT THAT ASWELL.NEAR PERFECT IMAGE.I DONT KNOW HOW THIS COULD BE ADAPTED TO USE THE PORTABLE AWAY FROM OFF THE FREEVIEW BOX.ANY SUGGESTIONS?
Aug 18, 2012 | Casio Portable Hand Held Tv - Model...
I can't get my CASIO model TV 995B open to replace the batteries.
Feb 15, 2010 | Casio (41644) 2.3 in. Handheld Television
No vhf or uhf channels
Not if it does not have digital tuner
Dec 30, 2009 | Casio 2.5" LCD Hand-Held Color TV...
Digitial reception for casio 980
You won't. Because the unit isn't likely to have an coaxial external cable input, there is no simple way to achieve this. Full-size sets not equipped for digital signals can accept the down-converted signal from a converter box that receives the digital signal and converts it to NTSC standards for older sets. Direct reception of the new signal requires an ATSC tuner and there is no way to provide that for your hand-held. It would be possible to use the output of a converter box clipped onto the antenna of your Casio and see the channels the converter box can receive but your hand-held wouldn't be very portable anymore. Sorry-
Aug 20, 2009 | Casio TV-980 2.3 in. Handheld Television
Jan 21, 2009 | Casio TV-900 2.3 in. Handheld Television
I have a Casio EV-570 hand held TV. Will this work after the switch over to digital broadcast.
According to CASIO website in Japanese, their portable TVs are not supporting Digital broadcasting and decided to cease production.
Thus it will not receive Digital broadcasting.
Although, EV-570 composite AV Input should still work for Camera, VCR, etc., I have not tried to connect to the DAC box.
My portable DVD without TV tuner worked with DAC box and now can watch digital TV program!
Jan 15, 2009 | Casio EV-570 2.5 in. Handheld Television
Will my handheld tv work after feb
Hello lavillavicto,
Look at you owners manual if the tuner format is ATSC (digital standard) then it's ok, if it is NTSC (analog standard) then it will not work. My experience tells me that the answer to your question is no, because most of these units were made with NTSC tuners. I know this is not what you want to hear but it is the truth.
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Dec 28, 2008 | Casio EV-550 2.5 in. Handheld Television
US Govt Digital Conversion
You will need to hook up a digital TV tuner to the device.
Goto dtv2009.com to request coupons for new tuners if you live in the US.
Nov 10, 2008 | Casio TV-880 2.3 in. Handheld Television
Nov 03, 2008 | Televison & Video
Tv reception on handheld Sony Watchman in Feb 2009
The old Watchmans are analog. If plugged into a digital cable/dish system it will scan in UHF and find the working channel than can be conrolled by your digital remote control. As far as taking it out on its own and working off the external antenna...those days will be over. Sony will have to manufacture digital Watchmans.
Jul 07, 2008 | Sony Watchman FDL-22 2.2 in. Television
Casio (41644) 2.3 in. Handheld Television Logo
119 people viewed this question
Top Casio Televison & Video Experts
Brian Sullivan
Brian Sullivan
Bill Boyd
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
