Question about Canon Office Equipment & Supplies
I press print. and blank pages go through the printer until paper runs out. i refill with paper and blank pages continue to go through printing nothing at all... its never ending. i have stuff due. what do i do??
  • Canon Expert
  • 141 Answers
The formatter board has gone bad, If this is a bubble or inkjet machine, then replace the machine as the machine is not worth repairing. if it is a laser machine then the formatter needs to be replaced, may also be a DC control board issue.
Posted on Sep 03, 2008
Color ink problem
Solution one: Check the ink levels To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary.
NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start (c01827528.gif ), click All Programs , click the HP folder, and then click the icon for your HP printer (c02053172.gif ). The printer software opens.
  2. In the printer software, double-click Estimated Ink Levels . The Toolbox opens.
  3. Click the Estimated Ink Levels tab to display the estimated ink level of each cartridge. Figure 1: Estimated ink level indicator c02752297.gif Image: Estimated ink level indicator.
  4. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
  5. Try printing again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Reset the printer Resetting the printer might clear the issues and allow the printer to function correctly again.
  1. Press the Power button (c01602202.gif ) to turn off the printer.
    NOTE: Pressing the Power button might not turn off the printer. This might happen if the printer is in an error state. Continue with these steps regardless.
  2. Disconnect the power cord from the rear of the printer. Figure 2: Disconnect the power cord from the rear of the printer c01869581.gif Image: Disconnect the power cord from the rear of the printer.
  3. Disconnect the USB cable from the rear of the printer. Figure 3: Disconnect the USB cable from the rear of the printer c01850063.gif Image: Disconnect the USB cable from the rear of the printer.
  4. Wait 30 seconds.
  5. Reconnect the USB cable to the printer. Figure 4: Reconnect the USB cable to the printer c01868577.gif Image: Reconnect the USB cable to the printer.
  6. Reconnect the power cord to the printer. Figure 5: Reconnect the power cord to the printer c01869582.gif Image: Reconnect the power cord to the printer.
  7. Press the Power button (c01602202.gif ) to turn on the printer.
  8. Try printing again.
Solution three: Restart the computer Restarting your computer might resolve the issue.
  1. Save the latest changes to your files, and then close all your open programs.
  2. Click Start , and then click Shut Down . A dialog box opens.
  3. Select Restart . Most computers turn off, and then turn on again automatically.
    NOTE: If a dialog box opens with a message that it is now ok to turn off the computer, press the power button on the computer to turn it off. Then press the power button again to turn it on. After a few minutes, the computer is ready to print again.
  4. Reopen the file that you want to print, and then try printing again.
Solution four: Check for blank pages in the print preview If the printer prints all pages correctly, but it adds blank pages to the printout, check for blank pages in the print preview.
  1. In most programs, click File , and then click Print Preview . If the program you are using does not have this option, consult the program manufacturer.
  2. Review the print preview for blank pages.
  • If the print preview reveals blank pages, delete the blank pages in the document, and then try printing again.
  • If the preview contains no blank pages, continue with the next solution.
Solution five: Check the USB cable If the printer connects with a USB cable, a faulty connection might cause the issue. Follow these instructions to check the USB cable.
  1. Make sure that the USB cable inserts all the way into its port on the rear of the printer. Use some pressure to push it in all the way. Figure 6: Insert a USB cable into the rear of the printer c01868577.gif Image: Insert a USB cable into the rear of the printer.
  2. Make sure that the USB cable inserts all the way into its port on the computer. Use some pressure to push it in all the way.
  3. If the issue persists, try replacing the USB cable with a known good cable.
Solution six: Check the printer settings on the computer Issues with the printer settings on the computer might cause the printer to print blank pages. Follow these steps to check the printer settings on the computer. Step one: Check the default paper settings Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)). Follow these steps to check the default paper settings.
  1. Click Start (c01827528.gif ).
  2. Click Printers and Faxes . The Printers and Faxes folder opens.
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences . The Printing Preferences window opens.
  4. Click the Paper/Quality tab, and then compare the settings in the Paper Size drop-down menu with the paper in the tray. If the size of the paper in the tray is not the same as the setting in the Paper Size drop-down menu, change the setting:
    1. Click the Paper Size drop-down list, and then select the size of the paper that is in the tray.
    2. Click Apply to save the settings, and then click OK to close the Printing Preferences window.
Step two: Print a test page Follow these steps in the order presented to print a test page. A test page might help determine if the printer installation caused the problem.
  3. Right-click the printer icon (c01532298.gif ), and then click Properties . The Properties window opens.
  4. In the General tab, click Print Test Page . The printer prints the Windows XP Printer Test Page. Figure 7: Example of Windows XP Printer Test Page c01532301.gif Image: Example of Windows XP Printer Test Page.
  • If the Windows XP Printer Test Page prints successfully, you do not need to continue troubleshooting.
  • If the page is blank, continue to the next solution.
Solution seven: Print from an alternate program Follow these steps to try printing from an alternate program, such as Microsoft Notepad or WordPad, to determine if the current program is causing the issue.
  1. Browse to the location of your saved document, right-click the file, and then click Open With . A window opens with a list of programs.
  2. Select a program other than the program you are currently using to print the document.
  3. Open the file in the program, and then check the contents.
    NOTE: Most files open in plain text applications, such as Notepad or WordPad, even if the contents include unusual symbols or text that does not make sense.
  4. Try to print the file:
    1. Click File , and then click Print . The Print window opens.
    2. Select your HP printer from the Select Printer drop-down menu, and then click OK .
    If successful, the printer prints exactly what displays in the program window.
    • If the document prints successfully in the alternate program, you do not need to continue troubleshooting. The issue is likely specific to the program you are trying to print from. Consult the program manufacturer for assistance.
    • If the document still prints blank pages in the alternate program, continue to the next solution.
    • here are a couple things you can try hope this helps you
Apr 19, 2013 | HP Deskjet 2050 All-in-One Printer
Lexmark T640 LCD blank..
To check if this is a hardware issue, please print a menu settings page. The purpose of this diagnostic is to check if this is a software issue or a hardware issue.
1. Press Menu to display Menus.
2. Press "down" until the "check" appears next to Reports.
3. Press "Check".
4. Press "down" until the "check" appears next to Menu Settings Page.
5. Press "check".
The message Printing Menus Settings appears on the display.
The printer returns to the Ready state after the menu settings page prints.
If the menu settings page printed without the dots, this would be a software issue. In that case, please call our Technical Support Hotline on (800) 539-6275.
Aug 17, 2012 | Lexmark T640 Laser Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Printer goes through the motions like it's printing, I don't get any error messages, you can see the ink cartridges moving back and forth, it pulls paper in and acts like it's printing, but the page comes...
Remove the cartridges and press the end with the ink sponges onto a paper towel. If you see ink on the towel, insert the cartridges and run the cleaning 3-7 times. This will use up some ink, but is the only way to resolve this issue. If you continue to see improvement in the prints, continue to clean until quality is acceptable.
Sep 30, 2010 | Canon PIXMA iP90 Mobile Printer
Printer keeps printing blank pages non stop going
drop kick unit across room:)))) sorry just kidding I had the same problem with mine. If the computer is continually printing that means the printer is receiving print orders from your computer. Best thing is just disconnect the printer from the computer and turn the computer off and wait 30 seconds then turn on . This should clear the print cache then reconnect the printer. Make sure to only request one print at at a time.
if the printer continues to print blank pages check to see if you have the latest software driver for the printer installed on your computer. You can do this by going to the manufactures website and download the software its easy to do just follow the prompts and install! Hope this helpful!!!
Jul 24, 2010 | Epson Stylus C84 InkJet Printer
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I refill my epson C60 cartridges and have a chip resetter. Now, the cartridges won't release ink when printing. I get a blank page. The printer recognizes the cartridges. What is causing the blank page?
Put the ink cartridge onto a damp paper towel.
Does ink "bleed" onto the paper towel?
If not, then the print-heads are clogged,
and you should run the "head-cleaning" software (part of the software package for the Epson printer).
Dec 30, 2009 | Epson Stylus CX8300 Printer
Leaking black ink on printed pages
Hi, please attempt to run a numerous blank paper through the printer. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains or streaks are still present, the printer may need service.
Tirzo
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
54 people viewed this question
old marine
old marine
