Question about Canon PowerShot A550 Digital Camera
Images taken in full sun are just diagonal slits with black on sides
Several images apparently are showing me the shutter half closed, with the image shown as a **** through the center. I have used the camera without this problem for 5 months, and 3 days after this with no problem. The shots were taken outdoors with auto setting. 9 were like this - all on full zoom.
  • Sandra Jaronski Sep 03, 2008
    No - only 9 of 60 were bad. One shot taken between the bad images was close up, zoom retracted, and it was fine. 30 taken after the bad images were fine.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Does it look like that in all of the pictures?
Posted on Sep 03, 2008
My screen is black and will not display images to shoot. Also when picture is taken it plays back as black image. Previously taken pictures will display.
Michele, a stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 19, 2011 | Canon PowerShot SD960 IS Digital Camera
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
Thre image does not show through the view finder or digital screen
If camera shows previously stored images correctly in playback but does not show live view in camera mode then it is ccd imager chip failure problem.
Replace ccd imager chip in camera by local camera repair shop to fix this issue.
Let me know if symptoms are different as above.
Sep 11, 2010 | Canon PowerShot S2 IS Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
My cannon is showing a black screen in the camera mode and the same after the image is taken..........i think the internal lens is not openeing............pls help?
Your correct in your assumption. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 14, 2010 | Canon PowerShot A540 Digital Camera
Camera shows no image through the viewfinder or on the lcd screen.pressing shutter button will actuate the camera, but only image is of a black box.using the display button to turn off the lcd does not...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 18, 2009 | Canon PowerShot S3 IS Digital Camera
Screen is showing no image it is showing details only
Jul 17, 2009 | Canon PowerShot S2 IS Digital Camera
Black lcd screen on Ixus 70 shows icons but will not take picture
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Half picture shows up and top portion is black
The camera firmware should be reloaded, if this fails then the camera is likely beyond end user servicing and should be repaired by a professional.
The reason your only seeing bottom half is as the reflex mirror is opening upwards to expose the sensor ( traditional cameras opened the mirror then a shutter to expose film ) your cameras sensor is only registering or transferring the bottom half of the image because it is the image is registered bottom first to the top until the shutter closes and the mirror returns to resting position.
Your problem could be the result of firmware or a more serious issue.
Aug 10, 2008 | Nikon D40x Digital Camera
Show only black when trying to take pic/video
This problem is caused by a stuck shutter assembly. Normally the shutter is open which allows light to enter the image sensor and show you the live preview you see on the screen. When you take a picture the shutter closes which allows the image sensor to record what was seen at the exact moment the shutter closed. The shutter is stuck closed, causing the image sensor to always be in the dark. These shutter assemblies are extremely small and delicate. The miniature parts can become jammed with just the slightest bit of oil or contaminant, or the slightest misalignment of components. The problem can sometimes be fixed by gentle tapping of the camera on a solid surface. If you are going to try this be VERY careful, and do not tap the camera on the buttons, lens, or battery door. If this does not solve your problem then the camera is going to have to be taken apart and the shutter cleaned and reset to allow free movement. This repair costs $125 to $145.
Jun 13, 2007 | Nikon Coolpix 3200 Digital Camera
Canon PowerShot A550 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
