Question about Carrier Heating & Cooling
The fan motor doesn't come on with the central air nor if I switch the fan switch to "ON". But the fan motor comes on if I switch to heating.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This is an either - or.. thermostat or bad green wire . To find out ,go to the unit where the thermostat wires are, or the terminals strip ,and connect the red wire from the unit to the green. Or connect a jumper wire straight to the red to green terminal strip. and it should start. If does then the problem is the thermostat or the green wire so go from there!
Posted on Sep 03, 2008
Central air conditoner outside unit
Well, the answer is yes. I have seen a bad capacitor cause a fan motor to run backwards. BUT..... After replacing the capacitor and WIRING it up the right way, everything should be fine. A lot of aftermarket condenser fan motors are reversible, so it can run counter-clockwise (CCW) or clock-wise (CW). However, most factory fan motors come one directional and on your specific unit, the air should always push out of the top. Running the unit with the fan going backwards will actually some-what do it's job, but damage other components like the compressor because it runs at higher operating pressures than what it is designed for.
Have someone else look at it! That's going to be the best advice I can give you. If they can prove that a capacitor caused the motor to permanently run backwards..... I want to know! Hope this helps and good luck with your unit.
Jun 22, 2012 | Heating & Cooling
The fan in the motor outside doesn't switch off when split system is switched off inside
Outdoor board or wiring faulty . you need someone to come look at it.
Jan 30, 2012 | Heating & Cooling
Just moved in to new house with central air. Despite turning all 3 zone thermostats to off (ie no cool, no heat), there is still air being blown through vents throughout the house. (fan switches are also...
You should not have the blower fan running if all thermostats are set as you say. You either have a relay problem in the air handler or the zone system wiring or controller is defective.
Sep 01, 2011 | Honeywell Heating & Cooling
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
I have carrier central airconditioners (4) in my house. The fan motors on the outside with the compressor occasionally squeel and hang up - and the fan stops or won't start spinning. I can usually free it...
Dear friend! It's not lubrication problem. All motors pre-lubricated.Weaken capacitor. Replace capacitor immediately. Don't practice to spin with screw driver. It's not safety.Thanks.
Jan 11, 2011 | Carrier 38CKC036 Air Conditioner
I have a 561c central air unit. I just replaced the fan motor and capacitor 6 days ago. The unit ran great for just that long now the fan won't come on and the outside unit is hot to the touch, I can...
Sounds like you need another capacitor since it will run if you turn it by hand to get it started. If you have a clamp on ammeter check the current draw on the fan motor.
Aug 23, 2010 | Heating & Cooling
Fan unit does not come on.
Hello
if im reading this correctly,you need to push start your fan motor?
Either the motor start capacitor is bad or the motor windings are bad.
If the motor is not coming up to full speed or is faulty you will not get good cooling.
Sounds as you may need a new motor.
Jun 01, 2010 | Ruud Central System Air Conditioner
Rheem central air unit is blowing cold air but seems to be in low
If you have had a drop in how much air is coming out it is quite likely not fan related. The fan motors usually run or do not run. More likely it is a clogged air filter or some of your ducting has blown loose. Like water, air will go the route of least resistance. If your fan motor is not running at all, I would need model number for resolving that.
Jul 08, 2009 | Heating & Cooling
My Blower Fan doesn't come on and unit freezes up. I have had AC guy out and he says it is switch. Is this problem..?
The blower motor does have fan relay.or switch. Is this a window unit. If so it is he is right they go our often. If it is Central unit. The fan relay also go out quite often.
Jun 09, 2009 | Heating & Cooling
Heating & Cooling Logo
76 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
