Question about MSI K8MM-ILSR (MS6741030) Motherboard
Case wires to connect to motherboard
I cant see where to connect the audio case wires and i also have a bunch of other wires TPA- TPA+ TPB- TPB+ 3x ground and 1 power cable.
can you help pls
  • 33 Answers
Hello!
To connect front usb header see this diagram:
http://www.celtnet.org.uk/images/usb_connectors.gif
To connect front audio header see this:
http://www.celtnet.org.uk/images/audio_connectors.gif
Hope this helps!
Posted on Oct 02, 2008
No 10 pin connector on mother board for usb
So you have a case with front connections and no place to hook those up? You will have to get a different case, that is a nice motherboard.
Mar 31, 2013 | Cougar Black Solution Steel ATX Mid Tower...
Dynamic menu error. I cant open my phone menu. What would I do?? It says 'configuration error. please contact your network operator or service centre.
To get the phone working again, you need to download a W200i EUROPE_2 custpack (depends on your phone's package). You have to create folders that go tpa then inside the tpa folder, a folder named preset then inside that folder, a folder named custom. So, it goes tpa/preset/custom with the customize.xml ..., in the custom folder now zip it up so you have tpa.zip, put it in the MISC box and press flash.
Jan 21, 2010 | Sony Ericsson W200i Cellular Phone
I cant wire up my XBlade case's audio!
look through your motherboard manual it should have a layout in there
Jun 23, 2009 | A-Top XBlade Mid-Tower Case
Abit an7 motherboard front panel wiring diagram needed :)
Front pannel audio is located left of the pci slots
: : : . : : :   thats what it looks like         from left to right there are seven sets of pins 1234567.
3 and 7 should be the pins you want for a standard front panel audio as far as i see in the manual ICEBOX
Mar 22, 2009 | Abit AN7 Motherboard
Wiring manual for a thermalrock oceandome
Go here for complete motherboard support : http://support.asus.com/download/download_item.aspx?product=1&model=P4P800-E%20Deluxe Click on the + next to manual and it will take you here : http://support.asus.com/download/download_item.aspx?product=1&model=P4P800-E%20Deluxe  . Scroll down near the bottom of page to this copy : 'P4P800-E Deluxe User's manual for English Version E1867". Download a copy of the PDF file to file for reference.  I checked this manual and it has all the information you need, but you will have to quietly study it, and then print or  take down all the required information you need on paper, as you will have to turn off tthe PC and power to make all the wiring connections to the motherboard. Cheers,  geonz72.
Feb 14, 2009 | Thermaltake ThermalRock OceanDome Chassis...
Front panel audio connection to asus pk5 se mobo
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Eduardo
Oct 03, 2008 | Computers & Internet
My camera on my sony ericsson w580i does not work any help please to fix it myslf
You can add flash menus, change camera driver, change acoustics, add languages with FSX
You can upload stuff to phone either with own_custpack method or via FSX
Rest all remain same. Here is a list a of directories with information. Download the stuff and upload them
ifs/settings/acoustic/ >> Acoustics file
ifs/settings/camera/ >> Camera driver
ifs/settings/display/ >> Display driver
tpa/preset/system/desktop/flash >> flash menus
tpa/system/layout/ >> layout.xml
tpa/system/system/mutlitmedia/mp/skin >> Walkman 2 skins
tpa/system/preset/multimedia/pe >> frames , clipart etc
tpa/system/preset/multimedia/av >> visualizations
tpa/user >> stock pics and themes…
pa/preset/system/settings >> startup and shutdown screens ! all are GIF but with no extension tpa/preset/system/sound >> all sound files
tpa/preset/system/menu >> the famous menu.ml
tpa/preset/system/fonts >> fonts !
/usb/audio >> locked music (can be deleted with FSX only but not with phone)
/tpa/user/audio/ locked music
/tpa/preset/default/audio/ locked music
/USB/IMAGE >> locked images.. can be deleted
/tpa/user/image/ >> locked images
/tpa/prest/default/image/ locked images
;Locked Themes -> /USB/THEME
;Locked Themes -> /TPA/USER/THEME
;Locked Themes -> /TPA/PRESET/DEFAULT/THEMECheck out the FS for more directories and locations icon_wink.gifPlease check out the customization of phone tutorial for more. You can use either own_custpack method or FAR MANAGe
thanks rate it................
Sep 11, 2008 | Ericsson Cell Phones
1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Sep 01, 2008 | Televison & Video
Rewire the motherboard k7s5a
well really you just have to put the wires to where they fix right. but for some wires, they look the same so you have to find a lable on the side of the wire and try to find the same lable on the motherboard. in some cases there are no lablings so it would be much hard to tell you how. but if thats the case i will do so.
Jan 25, 2008 | EliteGroup K7S5A Pro Motherboard
How do rewire the motherboard k7s5a
Go to this Asus site. Fill in the needed information on the right. This will than take you to your board. Download the manual.
Using the manual you will be able to set up your switches.
On the board and it is very hard to see. Every pin has a plus sign "+", that is the power. Black and some times white is ground. Other colors like red and green are "+".
http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 03, 2007 | EliteGroup K7S5A Pro Motherboard
MSI K8MM-ILSR (MS6741030) Motherboard Logo
323 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
