`lacie hard drive
My lacie hard drive was almost full so i deleted about 8GB of material to make room for new files, but having deleted the file the hard drive did not register that any more free space was available. Its like the register is broken or something . ever heard of this problem before? could it also have anything to do with the fact I had started using it with my new mac lap top - in the past i have only ever used it with my old mac lap top. Is my external hard drive about to give up completely? I bought it in 2003 but never had a problem with it before? it's a lacie d2 Hd 120 gb FW DV
Empty your trash. and youu be pleased
Posted on Sep 07, 2008
My drive is full, I deleted files but it is still full. Can I compress the data
OK... have just the answer for you but you MUST have room enough for one more tiny program...
CCLEANER
Get it FREE from the links below!
Anthony
https://www.piriform.com/ccleaner/download
and the TUTORIAL is here:
How to use CCleaner tutorial Clean your Computer Free Easy
Dec 02, 2017 | LaCie 80GB Mobile Disk USB 2.0 80 GB Hard...
I mistakenly deleted my lacie setup assistant on my lacie starck 500GB before I could install it,i really would appreciate any help that could be provided.
you can recover deleted files with file recovery program. I had success with asoftech data recovery which is one of the best data recovery program. you can download the program from
http://www.asoftech.com/adr/
May 29, 2011 | LaCie Rikiki Go Hi-Speed USB 2.0 500GB...
Cant delete files off external harddrive. files disappear but no space is freed up? lacie porche fa
this sometimes happens when you delete files partially. Deleting file normally will send it to the Trash (MAC) or Recycle Bin (PC) . The file is not really deleted at that point. Make sure to empty the Trash or Recycle Bin and the space should be freed.
If this does not work, copy all needed files somewhere else, then format the drive.
Regards,
Jan 02, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
I cannot seem to delete the files from my Lacie hard drive. The message says that I have no authorization to the files.
use a boo table dos disk and use dos to delete these files, if you need more info on how to do , use a windows commander, or Norton commander 40
Dec 19, 2010 | LaCie Big Disk 500 GB Hard Drive
Lost my data from my imac drive trying to backup to my Lacie.
yes U can recover it... plz download the registered version from the torrent site of software know as DATA DOCTOR RECOVERY .. this software will help you getting back you Data if you did not formated the Hard drive.. thank u for asking Question..
Jun 23, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Information used- capacity used and available
Re: deleting the files, did you drag the files into the trash bin and then empty it? The files don't actually leave your drive until you 'Empty Trash' on your mac's doc. Hope this helps, not sure about your startup disc problem.
Apr 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Drive Full After Backing-Up Just Under 4gb of Files
Are you trying to create one giant zip file or something similar? It sounds as if your Lacie 250gb hard drive has been formatted with a FAT32 filesystem and you are running into the maximum file size limit of 4gb minus 1 byte. Try just copying your files without using any compression utility or try reformatting your Lacie 250gb hard drive with the NTFS filesystem instead.
Feb 07, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie silverscreen Utilities CD-ROM
The OS is hidden in memory, you can clear all files off the machine and it will still work.
The only requirements are the 4 folders:
Firmware
Movies
Music
Pictures
That's it!
New firmware can be found at www.lacie.com
Dec 24, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
