Ducted heating not turning on. Set thermastat higher then room temp. Green LED flashing 11 times, indicating transmission problem with antenna.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Checkout the co. webpage and model #'.
Posted on Sep 03, 2008
I have Omega EHE 100S ducted heating when I switch it on there is no response at all. Can you help me out?
If your green light flashes a normal 1 second flash continuously, it means your furnace has a normal heartbeat. If your green lite flashes so many times then stops and then flashes that many times again, then stops again, and repeats again, count the number of flashes, write down that number, then remove the fan door the schematic will tell you the trouble. If your furnace has a normal heartbeat, the thermostat or wiring from the thermostat to the furnace is opoen or faulty.
Nov 04, 2014 | Heating & Cooling
Weller WES51 does not heat up unless I turn to 700 degrees or higher
You may have a broken wire in the temp sensor in the tip of the iron or near where the iron connects to the base.
Jan 24, 2014 | Weller WES51 SOLDERING STATION
Thermastat wiring t6360
its normal always on the light for the indicator light of oven, if will go off the light if the heat inside reach by the set temp, and will on again if the heat inside will down.
the indicator light on its means the oven is in use. or some indicator light is on if the selector switch turn in other position.
Nov 02, 2013 | Honeywell Heating & Cooling
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
    From the installation guide for this AP, I find the following:
    LED Indicators
    The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
    802.11a Activity LED Amber
    The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
    The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
    802.11b/g Activity LED Green
    The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
    The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
    From this, it appears that the 802.11A radio is malfunctioning.
    Here is the Motorola support web page for this device.
    Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
    Goodman GMP075-3 not igniting. Everything cycles as it should but HSI does not glow. Thermostat is set to heat, temp approximately 10 to 15 degrees higher than room temp, blower motor starts, relay clicks...
    The flash code is due to the furnace not proving flame 3 times in a row. If you have a multimeter you can ohm the ignitor out to see if it is good. Depending on the type (silicon Nitride or silicon Carbide) you can verify if it is good. A silicon Nitride ignitor looks like a small thin straight bar type will ohm @ 11 - 18 ohms, a carbide ignitor looks kinda like a tuning fork (sorta) will typically ohm @ 40 - 92 ohms. anything outside of those ranges will require a replacement.
    Nov 02, 2010 | Goodman GMS90703BXA Heater
    Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
    Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
    Mar 24, 2010 | Honeywell Electronic Programmable...
    Position of ceiling diffusers for a ducted warm air heating syste
    You want the air to distribute through the room as evenly as possible. You don't want the air to blow down in one spot. In a room where a thermostat is located make sure the air doesn't blow toward the thermostat or this will make the unit turn off before the desired temp is reached.
    Nov 15, 2009 | Desa International CBN30T Central Heating...
    WES 51 LED not flash to indicate ready
    the iron has a temp probe inside the pencil, most likley the problem. also these have problems with the powersupply but usually it won't heat if its a power supply problem. best guess would be the sensor in the pencil
    Feb 23, 2009 | Cooper Industries Weller Soldering Iron,...
    Edgestar 12000 heating problem
    bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
    Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
    Heating & Cooling Logo
    96 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
