Question about HP Office Equipment & Supplies
Officejet 6310. It will not photocopy. The light does not come on when I lift the lid or when paper is fed through the feeder.
  • HP Expert
  • 141 Answers
The scanner has bit the dust, machine not worth the costly repair, replace.
Posted on Sep 03, 2008
Straight thin line prints on copies from feeder
When the paper is fed through Automatic Document Feeder (ADF) it is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying! For example see the below picture: -
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 18, 2011 | HP OfficeJet J4580 All-In-One InkJet...
How do i get rid of 2 vertical lines on my copies
lift the scanner lid and then open up the ADF (document feeder) mechanism off to the left.
There's a small glass under the ADF mechanism, and it needs to be cleaned.
Use a glass cleaner like Windex sprayed onto a lint free cloth to clean it.
That's it! put the ADF back down and close the scanner lid!
Problem solved!
Jul 24, 2011 | HP OfficeJet 6310 All-in-One Printer...
Like many other people I have a vertical line down the copy, using the document feeder, not the plate glass. on my HP officejet J5780 3 in one. Your advice is to clean the small glass plate. I look...
I dont have a picture at the moment but if you lift the document feeder up to expose the large plate glass, the small plate glass is normally situated at the extreme left hand side of the large plate glass.
May 29, 2011 | HP Officejet J5780 All-In-One InkJet...
Two black lines down the side of the paper when fed from the top feeder.
Most likely dirt on the glass for the ADF scanner, but try making a copy from the glass first by lifting the lid and placing the document directly on the scanner. If that is clear, then it is definitely dirt on ADF glass. The ADF glass is the smaller piece of glass you see when you lift the lid. Use window cleaner and a soft cloth to make sure that you have all traces of dirt, liquid paper, post it note glue. Look at the glass from very carefully because even the slightest bit of goop can cause scan defects.
May 04, 2011 | HP LaserJet M1522nf Multifunction Printer...
When I send a fax, a big line accures on the paper on the recieving end of the fax. This happens to everyone I send a fax to. What is wrong with my fax?
HP has a document to address this issue.
Click here.
There is a possibility that the scanner has failed as well, but try the cleaning process first.
Apr 12, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My HP Officejet 6310xi displays a vertical line when copies are fed through the ADF and when sending faxes through the ADF, the same problem occurs. What could be the cause?
Open the Top Feeder Cover
Clean the Roller with lint free cloth.
Lift the Roller a bit up and you will find a glass strip underneath the rollers
Clean the glass strip with cloth and close the feeder
Try scanning or copying. it should work
Regards,
Ron
Mar 04, 2011 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All in One - small paper being faxed is jammed. How do I unjam the paper?
Lift the scanner lid, then lift the black part of the fax - pull up hard for it to lift. Unjam the paper either still on top or gently lift the inner section and retrieve your jammed paper. Then put everything back together and you're right to go again.
Oct 08, 2009 | HP Officejet 6310 All-In-One InkJet...
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Copy problem hp 6310 all-in-one
Instead of pushing the Ok button you should push the "Start Copy - Black" or "Start Copy - Color".
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
37 people viewed this question
Ben Johnson
