Question about Gyration Ultra Cordless Optical Mouse
GP4101 Powere Supplay
Which PS i need for the Chrging Cradle, powere rating and polarity?
arik.bashevkin@panasonic.aero
  • 1 more comment
  • vickibla Feb 13, 2009
    I have a charging cradle of Gyration (model GP4101), and lost the power cord. I need to know the technical specifications to buy a new one.
  • hpernell Apr 25, 2009
    Lost my power ac adaptor to my gyrtion mouse charging cradle model # GP4101
  • gerardofranc Sep 30, 2013
    I HAVE SAME PROBLEM, I HAVE LOST MY POWER CORD F I HAD SPECS ABOUT THIS CORD I COULD BUY ONE.
  • 3 Answers
The Ultra AC Adapter has the following output specification.
Rated Output Voltage - 9 Volts DC at 200 Milliamps to 1.3 Amp Max
Center of pin Positive
Pin Size
Length - 9.5 mm
Width - 5.5 mm
Center Hole - 2.1 mm
Posted on Jun 05, 2009
  • revelman Feb 13, 2011
    tHANK YOU.
    iN TODAY'S WORLD THERE IS SO MUCH KNOWLEDGE. i OFTEN FIND SO MUCH PLEASURE IN SHARING. i TRUST YOU DO TOO.
Output 9v DC 200mA, center is positive.
Posted on Mar 02, 2009
How to charge a dwalt 14.4 battery with out a charger
Hook up to DC power supply of about 16-18 volts observing polarity.
If battery pack is rated 3 amps and the PS has an output of about 500 MA, divide the 500 into 3 amps and you get about 6 to 7 hours of charging time.
Sep 09, 2015 | Cameras
I need a replacement power supply/adaptor for the US-428. I need the PS-P428 adaptor. Can you please help me find one?
Seller solenoidal on Ebay has the 7.5 volt a/c transformer that the Tascam US-428 requires. If the plug is wrong, cut off the old one and splice it on. No need to worry about polarity with a/c
Aug 06, 2011 | Tascam PS-P428 Power Supply...
Panasonic PT LC76U Multimedia Projector Lamp how do i reset the timer
press the MENU button to display the menu screen, and then press the UP and DOWN aero button to select the "OPTION" menu. press the ENTER button and then press the UP and DOWN aero button to select "LAMP RUNTIME". Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" screen will be displayed.
(NOTE: press any button other then the POWER button to cancel the "LAMP RUNTIME" screen)
Press the POWER button to turn off the power.
The POWER button on the projector illuminates red.
This will reset the cumulative usage time for the lamp unit to "0"
Jan 12, 2011 | Panasonic PT LC76U Multimedia Projector
Power steering rack
jj, here's the procedure:
turn ignition key to locked position and turn steering wheel to the left until the wheel is locked. Remove key.
While vehicle still on ground disconnect the steering column shaft coupler from the steering gear intermediate coupler. Remove the cotter key the nut and the pinch bolt.
Loosen wheel lug, raise vehicle support securely w/ jack stands, remove the wheels.
Raise the insulating wrap on the power steering return hose to expose the hose clamp. Remove the hose clamp and detach the hose, Drain ps fluid thru the hose.
Remove both tie rod ends from steering knuckles.
Remove the 2 bolts and loosen the 3rd attaching the anti-lock brakes Hydraulic control Unit (HCU) to the suspension cradle.
then rotate the HCU rearward to allow access to the cradle bolt and nut just forward of the hcu.
Remove the nuts and bolts attaching the cradle plate to the bottom of the front suspension cradle, then remove cradle plate from cradle.
Remove bracket attaching power steering fluid line to the front suspension cradle.
Detach ps.fluid pressure and return lines from the ps gear.
Remove the 3 bolts and nuts mounting the steering gear to the front suspension cradle.
Lower the steering gear from the suspension cradle enough to allow access to the intermediate coupler roll pin. Install a roll pin remover/installer tool (they always get u with that darn special tool, don't they?) or equivalent set up. Pull the roll pin out of the intermediate coupler. Separate the intermediate coupler from the shaft of the steering gear Remove the steering gear assembly from the suspension cradle. Well, it's too late to give the install procedure, but u seem to have it under control, so let me know if u need more info and how u make out! Merry Christmas!
Dec 18, 2008 | 1998 Dodge Caravan
I have a panasonic steam microwave and the powere inverter fault has been diplayed. Can yo helpo please 1
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 04, 2008 | Panasonic Microwave Ovens
I have to replace my Powere steering pressure hose on a 2002 Mitsubishi Lancer. can I do it myself
if you have basic hand tools and some knowledge of auto repair i would say you've got a shot, be sure to take your time with it and replace the tiny little o-rings on the fittings rout the line out of harms way and properly bleed all the air form the power steering when your done, i would rate this a 7 on the 1-10 scale only because it is crucial you get all the air out otherwise damage could result to the power steering pump good luck and please be sure to rate this -jeff ps you may want to pick up a ciltons manuel it will make your life easier and will explain the proper air bleed procedure
Sep 13, 2008 | Mitsubishi Lancer Cars & Trucks
Phone issues.
1st) you must identify the ranking order of your handsets. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset. Go to the main base cradle. On the bottom, where it says "locator" press the "select" button until you get the desired phone rank needed. H1,H2,H3 etc... Then, press and hold the "call" button, under "intercom". (The charging light should start flashing) Now, go to your handset and press the "OK" button on the top upper right corner. At this point, your phone should be working!
If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support. PS: your handset may show model KX-560B, but your main cradle base will show the actual phone model listed as KX-TG5633
Mar 14, 2008 | Panasonic KX-TG5633B Phone
I lost my charger and need to charge tonight.can i charge this with the usb cable and my computer?
i suppose u charge via USB? no need of software but i am not sure usb can handle the power for chrging the cam corder
Feb 05, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
Gyration Ultra Cordless Optical Mouse Logo
1,534 people viewed this question
Top Gyration Computers & Internet Experts
sonic boom...
sonic boom...
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Gyration Computer and Internet Expert? Answer questions, earn points and help others
