Question about Hitachi 53UDX10B 53" Rear Projection Television
Digital tv I have a projection Tv 53UDX10B do I need a converter box to get TV signal over roof top antenna
  • 2concept Sep 03, 2008
    I just want an antenae that will permit me to view local channels clearly
  • 927 Answers
Good Day, tuff65;
Today with "HD TV" get a good UHF/HD antenna. You can get at any local Best Buy, Circuit City, Radio Shack etc.
Good Luck, big IRISH. PS: Inside or outdoors.
Posted on Sep 08, 2008
  • MICHAEL MULLINS Sep 08, 2008
    If your TV is not HD yes!!
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Does a r57w46 zenith tv need a converter box
General rule of thumb: If your original remote does not have a dot ( .) or a dash ( - ) near the numeric buttons, the TV is does not have a digital tuner. These buttons are used to directly enter a digital channel number such as: 19.1 or 19-1. After looking at your TV specs, this TV needs a converter box if you plan on using a roof top antenna. I hope this was helpful, best wishes.
Jun 29, 2010 | Zenith R57W46 57" Rear Projection...
I have the converter box i have a plasma samsoung do i nstill need a antenna
Yes,u need a good antena,like a digital antena or a roof antena to recieve good free air DTV signal.U don't need a converter box,because ur tv is a digital tv.
May 04, 2010 | Samsung LN32A330 32 in. LCD TV
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Mar 11, 2010 | Digi Sansonic FT-300A tal To Analog TV...
Samsung hlp 4663w does not receive off air signal from roof antenna through antenna ports 1 or 2. Get cable signal just fine through same ports. Same antenna works fine on other tvs. Whats the problem and...
If you're in the US, you will no longer get antenna signals because the US has recently switched to digital. The TV you have does not have a digital tuner and you'll need to purchase a digital converter box that converts a band of analog signal to digital.
Feb 03, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
My new tv digital converter box weill not pass analog tv signals. The tv works fine if I take the box out of the circuit. I am in a motorhome using the normal tv antenna on the roof.
you need to split ant. signal then get a manual selector switch hook 1 wire to convertor input then the output& the other ant wire to the selector switch then from selector to tv
Dec 20, 2008 | RCA Televison & Video
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Oct 10, 2008 | Zenith C27A24T 27" TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
106 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
