Question about Dell Axim X5 Pocket PC
Align screen loop?
I just got my Axim X5 and I can't even get past the "Align Screen" screen to set up the unit. After I tap the tatgets into each corner, it goes back to center and seems to be in a loop and there's no way to get out of it. Any suggestions?
    Problem Solver:
  • 10 Answers
Look at this http://www.fixya.com/support/t132057-getting_past_align_screen
you basically need to get the wire to stop touching the home key, which can be accomplished (as described in the link) with either the quick fix method, wedging something in the bottom screen, or the better-long term method of opening the axim up and taping the part that has shorted.
best,
Greg
Posted on Jun 14, 2008
SOURCE:
The align screen function won't work properly. I've tapped the target many times, but the screen won't change
I had the same problem and I got it to work by placing a paper just above the Dell button and the touch screen. There seem to be some part of the metal cover that shorts out the touch screen and causes that problem. Some other people have recomended taking the unit apart and placing electrical tape in that area. Hope this works for you. Good luck.
Dec 12, 2010 | Dell Axim X5 Pocket PC
Screen alignment loop
The only thing I can think of is that the screen might be bad. Has it been hit or dropped? Are you SURE you haven't thrown it against the wall? :P Just kidding, but seriously, my dad's old Palm had a similar problem where if you tried to calibrate the screen, it would loop, and it was because the screen was old and wasn't performing correctly. Although you were pressing it in the right place, the screen wasn't reporting the locations properly, causing the thing to loop to try and get correct readings from the screen.
Dec 04, 2007 | Dell Axim X50v Pocket PC
Align Screen stuck in loop after hard reset and clean
Hello, I could be able to diagnosticate your problem but first I need to know some more details. At the current state, can your pda be connected to active sync ? (you may try using it's cradle or usb cable) Can you manage to pass in some way of the align screen message? Does the screen respond to taps? When you tap the screen trying to callibrate does the cursor moves or does something? Please try to explain these questions and I'll be back with an answer as soon as possible. Thanks for understanding.
Jun 12, 2007 | Dell Axim X51v Pocket PC
All I get from my Axim x30 is the align screen. When I tap all the crosses it just stays in the middle but I dont get the home screen, not even after a soft reset.
take a credit card or bisiness card and slide it in between the edges of the screen gently this should fix the problem if not open it and clean the touchscreen contacts
Aug 24, 2010 | Dell Axim X5 Pocket PC
Dell Axim X5 won't stop alignment. It says to tap the screen to align, but it never finishes the alignment. I keep tapping and can't get it aligned, thus the Dell can't be used cause the program never...
ok, i see your problem.You could clean the screen of your pda using a business card. Gently, wipe the corners of the screen. This is the best way as unresponsive screens occur due to lack of attention as dust migt be trapped under the screen.Hope this works.GOOD LUCK
Jun 21, 2010 | Dell Axim X5 Pocket PC
I bought a cheap Axim X5 PDA and I believe it is missing the top "door" but I am not sure, as I bought it from ebay, and don't know anything else about it. Also, it needs a back up battery cover. I am...
Dell Axim5 Top Door is for Compact Flash car. the Battery Backup is the one to maintain the memory alive, but if you still have main battery good is supposed the memory remain until you go out of battery. I have one with some reason the battery backup do not function, so I have to backup all data.
Jul 02, 2009 | Dell Axim X5 Pocket PC
Align screen
best,
Greg
Nov 02, 2007 | Dell Axim X5 Pocket PC
Axim X5 Align Screen Loop
I am by no means an expert but I have had the same problem that you are having and I found that after I took my X5 apart and cleaned around the underside edge of the plastic housing frame that was at the edge of the screen the problem went away. I also cleaned the front of the screen very well and put a new back-up battery in. I have not had the problem since.
Sep 05, 2007 | Dell Axim X5 Pocket PC
Dell Axim X5 Screen Back Light Trouble
Holding down the record button on these units turns the backlight on and off, since this is hardware controlled you should try this first. If you've performed a hard reset and held down record then this is most likely a physical fault, check with Dell to find out your warranty status and find out about the availability of replacement parts.
Aug 28, 2007 | Dell Axim X5 Pocket PC
Getting past the 'Align Screen'
Had the same problem starting about 3 months ago with my Axim X5. Couldn't get the touchscreen to respond in order to input my password. However when I sync it to my computer I had better success at getting the touchscreen to work and respond. Tried the business card tip of sliding it between the touchscreen and metal cover/frame of the PDA and now it seems to work even better. Great tip. Hope it becomes the more permanent fix for getting my PDA touchscreen to respond. Mack
Jan 28, 2007 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
537 people viewed this question
Clive
Clive
Alun Cox
