Question about Microsoft Windows XP Professional for PC
Bsod in windows xp
No there is no file like that in the windows folder.
  • ossa_2pac Sep 25, 2008
    s offered
  • Roberta Smith
    Roberta Smith May 11, 2010
    what exactly was the error message ?
    Robert
    Problem Solver:
  • 8 Answers
Please install latest antivirus. and try.
Posted on Oct 24, 2008
While installing xp sp3. Error message: file missing check i333
Are you sure i333 is not actually i386? The i386 folder contains all the files Windows uses to install XP. If you have XP installed already and it is asking for the i386 folder, it wants you to put the original Windows XP folder into your CD drive. If you are attempting to install Windows XP with SP3, there is something wrong with your CD. To avoid this problem in the past you can do this:
Copy Windows XP Installation Files to Local Hard Disk SourcePath Raymond CC
Feb 07, 2017 | Computers & Internet
I try to load windows xp or 7 and as it starts to copy files i get the bsod. ive tried to reinstall over 5 times and while its loading it come up with the bsod
Have you done a disk scan of the hard drive? Did you set a partition and make it active? Have you tried letting the software partition and format the drive?
What error codes were provided with the BSOD?
Mar 09, 2015 | Computers & Internet
Toshiba sr3 laptop wont start
Access internet, download Symantec Power Eraser. Run program.
Problem is initiated before hard drive is recognized. Program is FREE!
Feb 26, 2014 | Toshiba SATELLITE PRO M70-SR3 LAPTOP LCD...
Fix the BSOD problem
before doing anything else, press F8 at startup to enter into Safe Mode and try to see if you can copy or backup your files.
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied.
see this guide
http://michaelstevenstech.com/XPrepairinstall.htm
Jan 21, 2010 | Dell Latitude D620 Notebook
Plugged in the 1TB WD My Book Essential into my Dell Dimension 3100 running windows xp and the screen goes blue and I get a error stating "Bad_Pool_Header"
here's a solution I found on google:
BSOD the Solution:
Did you install Service Pack 2? Are you now suffering from the Blue Screen of Death (BSOD)?. Here is the solution. I have spent 4 days hunting down the cause of my machine crashing and have finally cracked it. Maybe other people have a different cause than mine so my solution may not work for everyone.
After installing SP2 I suffered many crashes. In particular the Screen would turn blue and display a message starting "Bad_Pool_Header". And ending with STOP: 0X000000019....
Then my four day hunt for the cause started.
BSOD Solution
Basically I found two causes of the BSOD.
Cause 1: Corrupted file or folder.
Cause 2: Microsoft Indexing Service
Possibly these two causes are linked.
Solution for Cause 1
Onen up Explore (right click the start button), and expand your directory tree, starting from the C: drive. Click on each folder in turn and see if any cause the BSOD to appear. If so, reboot, and simply attempt to copy the folder, and then delete it.
Solution for Cause No 2
Switch off Microsoft's indexing service. You can do this by clicking the start button, select "Run", then type "msconfig", then select the "Services" TAB, scroll down to the Indexing Service and Switch it off. Reboot your computer, and good luck - maybe it will work, It solved the problem for me.
At first I thought I must have a third party software or hardware conflicting with SP2, but even after I had disconnected the internet, switched off all items in the startup TAB of msconfig, was still getting the BSOD. I tried surface scans, chkdsk, scan disk etc all to no avail. I tried defragmenting the disk, but the frequent crashes may have made things worse.
I discovered the computer was now crashing after about 7.5 minutes of being switched on. It did not matter whether anyone logged in or not.
Finally I went to msconfig (Start Run, MSCONFIG) and switched off "process System.ini files, Load System files, Load Startup Items. And the comuter stopped crashing. So then I added the item back one by one until I discovered the Microsoft Corporation Indexing Service which was causing the crash. I switched it off and switched everything else back on and AT LAST... No more BSOD
Jan 01, 2010 | Western Digital My Book Essential 1TB...
BSOD error 7E at windows startup
you can download xp with sp2 as long as you have your install codes..then as long as you dont fdisk or format your hard drive.. just reinstall the xp..youll be able to save your stuff..when asked to use same directory for install select no and rename the directoty where windows will reside...then when your done..youll find your stuff..
Nov 10, 2009 | Cell Phones
Bsod, error code:0x00000024, hdd problem booting xp os
Can you do this
Boot from the Windows XP CD.
Watch for a Press any key to boot from CD... message similar to the one shown above.
Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console
Select your OS and enter password (if needed)
When you reach the command prompt type the following and then press Enter:
expand d:\i386\hal.dl_ c:\windows\system32\hal.dll
Using the expand command as shown above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\windows represents the drive and folder that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite the file, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Apr 24, 2009 | Sony VAIO VGN-T170P/L Notebook
Kernel error
Use the XP CD to boot from.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the admin password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Also while in recovery console type in sfc /scannow to check all files.
Type exit to reboot the computer.
See if that works
Apr 20, 2009 | Dell Inspiron 8600 Notebook
Bsod in windows xp
you clean your ram ..........then restart pc...........
what problem display on your pc ???????????
Aug 08, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional for PC Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
