Question about Siemens Refrigerators
KS39V60 Siemens Fridge - seems to have warm spots in the fridge ie. temp is not consistent and food is spoiling - any advise?
  • 55 Answers
SOURCE: Fridge smells
Are there any drip channels in the back or bottom of the interior of the unit that may be clogged? These channels collect condensate and feed them to a pan under most refrigerators. I assume you have removed bottom food storage drawers and cleaned inside. Also try open box of baking soda which absorbs odors.
Posted on Feb 27, 2008
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
SOURCE: fridge not cold
I have a side by side fredzer and refrigerator digetal thermometer . The freezer temperature will not go below 54 or 53 and the refrigerator states at 43or 45.
Posted on Aug 29, 2008
I think that I have a solution. Refridgerator side not cooling.
I read in the blogs that holding down the top two bottons(power cool & fridge) at the same time resets the refridgerator control panel.
I may have caused the problem by leaving the door open. If my above solution does not work, then I will defrost the frefrigerator just in case the coils are froze up. It works with my air conditioner.
Posted on Feb 23, 2009
  • 1122 Answers
SOURCE: Fan runs constantly and does not keep temp cool enough
forst on the back wall means you have a defrost problem or a air leak aroudh the door gasket-mike
Posted on Mar 16, 2009
Warm temp. on door of refrig.
The fan on your freezer may have given up thus the cold air inside the fridge doesn't circulate.
Apr 12, 2014 | Whirlpool Refrigerators
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 15, 2009 | Refrigerators
Fridge part has dropped temperature, doesnt appear to be cooling. Temp reading - no number. In Chinese, don't know how to reset it ???? Hope you can help before my food goes off - Freezer is working as...
I took a lot of non essential items out and that seemed to fix it, either there was not enough circulating air ie something was jamming a sensor I cant find...any way fixed it thanks
May 12, 2009 | Siemens Refrigerators
Whirlpool refrigirator with top freezer
run your hand around bottom door seal see if you can feel a warm spot, if you do check that area for contamanation ie;particals of food etc if not pull the seal in that area back slightly see if seal is split.if all seems ok look at the drain hole at the back of your fridge inside it often clogs up with small particals of food if this is the problem use a pipe cleaner to clean it.if its cloged water will be seen lying at the bottom of your fridge ;if any of the above do not cure your problem turn down your fridge a little this will not affect your freezer.hope this helps you.adrian
Jan 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Food gets spoiled too soon
the problem is gas build up in your fridge
use arm and hammer baking soda boxes for the fridge.
that will help a lot
Apr 30, 2008 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
I have FRT18B5AW7, the freezer workes fine but is frosting. The refrigirator is getting warm and all food is getting spoiled. This might some defrost problem. What is exact problem. where defrost timer,...
Is this fridge new?
Does it matter how cold you crank the dial on the fridge -- does it just stay the same temp?
If so, i had this problem with my new fridge.
The manufacturer did not connect the fan before shipping it out. Therefore, the cold air collected in the freezer (alcohol would freeze to sluch) but the fridge stayed the same temp (all the food would go bad).
Since it was still under warranty they fixed it.
Repair man came out, took the freezer apart from the inside and rehooked up the fan. Has worked great ever since.
If this isn't a new fridge than my guess is that the fan has stopped working and might need to be replaced.
Hope this helps.
Good Luck.
Apr 21, 2008 | Refrigerators
I have noticed that fridge seems to be running alot lately I did all routine maint. cleaning coils etc. and it still seems to be running alot. model number is afd2535dew top fridge french door. Is there an...
not really sure as far a swhatconstitutes ruining along time, you are doing the right thing by keeping it clean for sure, refrigs now run for as long as they need if it never stopped running youd see hte effects of that in 2 ways, either all your food would be FROZEN solid( cause it never shuts off), or your food would be spoiling quicker hat n usual, in which case your refrig is trying to run all the time to maintain temps! the noise that you hear running might just be the evap fan motor running( circulater fan, sure its gonna run to circulate, but the compressor wont be running all the time.. check and go by your dairy products, ice cream too hard or too soft, and in refrig check the milk and butter.youll never know how cold you leftover is but youll know right away if the milk it too warm
Mar 19, 2008 | Refrigerators
Refrigerators Logo
76 people viewed this question
Top Siemens Refrigerators Experts
marlin siecinski
David Ellis Rhea
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
