Televison & Video Logo
Posted on Sep 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AV1 AV2 DVD Connectivity
Please guide me in connecting AV1 or AV2 or DVD in Hard rock 29" TV
  • Hari Govind Sep 03, 2008
    I'm not able to find the solution in the information provided.
    Thanks.
Anonymous
Level 3:
  • Master 2,071 Answers
  • Posted on Sep 03, 2008
Anonymous
Master
Level 3:
Answers
2071
Questions
Helped
1014722
Points
5371
Just click below for more information;
http://www.fixya.com/support/t997470-hooking_up_sony_sa_wm20_audiophile
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
1helpful
2answers
How do I hook up a dvd player
yellow, white and red wires usually connected to the same name same colors on both devices.
Does the tv need to be on a certain channel? YES, try change to all ex: VIDEO 1, VIDEO 2, DIGITAL, ANALOG, HDMI or any according to tv sysem
5answers
My sony dvd is not playing on the tv. all cables are color coded and plugged in correctly
Look at the guide below use AV1 or AV2
Match the colors vertically
Click on "INPUT" key a blue screen will appear Choose AV1 or AV2 according the connection you have made at rear panel
Please let us know the outcome so we can try alternate ways to help you.
Good Luck
My audio and my picture are on two different channels like i can see the movei on av1 but i cant hear it but if i turn to av2 i can hear it but not see it
sir, check the cable which is connects TV and DVD player Audio Video cable ... both should locate at AV1 port in TV and DVD... else AV2
2helpful
Hi there, I am getting some problem in connecting my DVD player to LCD TV on AV2 port. If I connect the same to AV1 port,it works fine but that port is already in use for my set top box so if I want to...
I expect if you look at the menu you will find that AV2 is set up as S-Video or Component etc. etc. Set it up as composite or RGB. The same as AV1.
Srt 2219b im try to setup to watch dvd and vcr. is there a trick.
If you are connecting your DVD and VCR to the TV using Scart leads, simply go into TV input option on your tv remote and switch to AV1 or AV2. i.e AV1 for VCR or AV2 for DVD player.
Where to put scart leads into dvd and video player and panosonic tv
Look at the rear of the TV/VCR/DVD & you will see long black sockets where the Scart cable is connected onto, these are normally indicated as AV1/2 etc. You can then take Scart from DVD to TV on AV1. Then on AV2 take the second scart from VCR to TV or you can take the second scart from the DVD to the VCR & from the VCR to AV2 on the TV.
1helpful
How do i connect dvd recorder to tv only receiving sky channels through skybox
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
1helpful
Correct hookup from satilite receiver to dvd/vcr to tv
Av out from sat to AV1 on TV.
AV2 from tv to av in on dvd/vcr .
( if you can pick what av2 on the tv sends out set to send av1 out to record)
OR
AVout from sat. to AV1 on TV, AVvideo on sat to vcr/dvd.
The sat. system will act as a "play through" device so you can play vcr/dvd without changing the AV on the TV.
If you connect another lead in either option you may get a feedback loop causing audio "squeak" and video problems.
Post back to let me know if this helps.
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the TV...video and audio should be connected to IN.
Dmr-ez25eb sometimes get just
problem solved.
just used av2 socket on tv instead of av1
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
