Question about Acer Aspire E500 PC Desktop
Not Starting, even though fans running, CD Drive operating.
My PC started to trip without any alarm, since last 10 days, but for the last 2 days this is not getting stated even. Whenever I plug on the CPU, without pressing the CPU's ON switch, its fan start running, DVD drive comes in operating mode (on light signal of DVD drive keeps stay on the CPU display). CPU has a feather touch ON/Off switch and ON display light of the CPU is not turning ON even after pressing it. It is behaving as if it were in sleep mode (hibernation).
Kindly help solving my problem. If possible, please mail me at tayalmohan@yahoo.com.
With best regards,
Mohan Tayal
India
  • 83 Answers
SOURCE: Wont boot
DO YOU KNOW WHAT A MOTHERBOARD IS?
IT MIGHT BE A PROBLEM WITH THE CPU....TAKE TO A COMPUTER REPAIR SHOP
IF THESE CONDITIONS WERE FROM THE BEGING, WHY DID YOU NOT TAKE IT BACK TO WHERE YOU BOUGHT IT FROM, IT MIGHT BE DEFECTIVE....ALL CD DRIVES ARE REMOVABLE.....SOME ARE JUST HARDER....
Posted on Feb 21, 2008
myjosh007
  • 530 Answers
SOURCE: Aspire AM1201 does not boot up.
hi im josh in cebu phil. try to enter bios set up.go to power menu.then try to change the setting of power loss to shorter time then save the changes then restart your pc. good luck.try to txt if problems continue.
Posted on Feb 17, 2009
  • 59 Answers
SOURCE: booting problem
DEAR,
AS PER YOUR PROBLEM I THINK YOUR COMPUTER WORKING WITHOUT ELECTRIC EARTHING. PL FIRST COMPLETE EARTHING WITH ELECTRICIAN.
YOUR EARTHING IS NOT PROPERLY PL CHECK THAT:-- ELECTRIC SHOK ON PC BODY.
YOUR PROBLEM WITH POWER SUPPLY OR PROCESSOR,MOTHERBOARD.
PL FIRST CHECK POWER SUPPLY,SECOND CHECK YOUR PROCESSOR WITH ANOTHER PC MOTHERBOARD.
Posted on Feb 25, 2009
skdeepak88
  • 232 Answers
SOURCE: Wont boot- no signal on screen after a few moments
The problem is with your RAM. Dust it and re install it. It may work. If you cant get it fixed get your friends RAM and see if it is working. Check if you get any beep sound from the PC. If so the problem is with RAM and need to be changed. Thanks!
Posted on Aug 16, 2009
BlacMamba
  • 215 Answers
SOURCE: it wont run programs
remove the RAM chips,blow off any dust that musta settle'd on it...and swap them into diff slots
Posted on Nov 11, 2009
How can i stop the squeallng noise in my dell d 610
There are 3 moving parts with motors on a laptop.
1. The HDD
2. The CPU fan
3. The CD/DVD/Blue ray drive
Check them
If it's the HDD than you will be having problem with the operating system. Back up your data and change with a new HDD. 50$ to 80$ depending on your choice of HDD.
If it's the CPU fan it might be touching a cable or the casing. For this you need to dismantle the laptop and clear this out or change the fan. 10$.
If it's the CD/DVD/Blue ray drive than the laser eye is starting to loose it's ability. You will need to change the drive. 30$ to 50$.
Good luck mate.
May 26, 2014 | Dell Latitude D610 Laptop Computer -...
Aspire 4738 Z
Try a replacement charger as if that has leaking components, it may take a while to produce the correct power required to run your laptop.
Dec 11, 2013 | Acer Aspire Computers & Internet
We have 2 IR air compressor Model No. SSR-EP75 that are tripping on high air end temperature frequently. We have monitored the temperature using a data logging system and have not found any regular pattern...
First what temperature is it tripping at ? Have you removed the oil fill plug and visually inspected the oil level. It should be filled to the oil fill plug threads. 228 degrees F is the temp the air end temp sensor should trip the unit at, approx. You need to know the ambient temp. where the unit is located. add 100 degrees F to the ambient and that is what the unit should be operating at. ( ex. 100 + 95 amb compressor should operate at approx. 195 degrees F.) If the unit is tripping at 180 or even 215 you probably have a bad temp sensor. It would be unusual for 2 units to have temp sensors go bad at the same time but it could happen. OK if the unit is tripping at or around 228 check the following: Oil/air cooler - (Radiator). It should be clean on both sides. It can be blown out with air or washed out with a 1200 psi pressure washer. When complete you should be able to see thru the cooler, and have good air flow thru it at any location especially corners. Next the thermostat could be the problem. when starting the unit up cold check the return line from the cooler with your hand. If the panel reads 190 to 200 their should be oil flowing thru the cooler. if it stays cool replace the thermostat. The thermostat should open at 170 degrees F. If you have a temp gun use it to check temps on the 3 lines from the thermostat. you are looking for a 25 to 30 degree drop across the cooler. Last but not least if all looks good and the unit is just prematurely tripping you may have a controller going bad. Sometimes these controllers will trip on some alarm. At first it may be once per month then once per week then once per day then several times a day until it gets to where it will not run without tripping on some alarm. Good Luck.
Sep 07, 2011 | Ingersoll Rand Air Tools & Compressors
Lookbook will not power on
A computer that won't start can be both alarming and infuriating, especially if you're on a deadline or you haven't been backing up all your data (like we all tend to do). Don't panic, though-this problem often has a simple solution.
1.If your desktop computer does nothing at all when you try to start it, first check that the power cable is securely plugged in at the back of the computer as well as into a working power outlet. It's amazing how often this is the case.
2.If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
3.If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector, it will need to be replaced.) Try plugging a lamp or other device into one of the surge protector's outlets to make sure it's working.
4.If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
5.If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
6.If the operating system still won't start even though the computer and monitor have power, try restarting with a Windows CD-ROM in the CD-ROM drive or, if you've got a Macintosh, with a Mac OS disc in the CD-ROM drive. (You can start a Mac from the CDROM drive by holding down the C key while starting up.)
7.If the operating system then starts, your problem is probably with the startup hard drive or with the operating system installed on it. If you can't fix the drive, you'll have to replace it. (See also How to Fix Bad Sectors on a Hard Disk and How to Recover Lost Files.)
Aug 26, 2011 | Computers & Internet
My Dell Inspiron 1545 lap top is not working. After switching on the laptop it is not doing any thing except glowing the LED. Even it's fan is not working. But LCD is working fine. I tested the LCD screen...
If it''s giving any beep tone while starting then your PC has some hardware related issues contact dell care or service center
If not
You need reinstall the operating system To reinstall you need *A copy of operating system(must be compatible with your processor type) loaded in a DVD or a CD
To reinstall *Insert the os CD to DVD drive *When your PC's logo appears press F12 *Select boot from DVD/RW++ *Select "INSTALL NOW"(in windows operating system) *Select a drive in which the operating system is to linstall *Follow the Instructions....
Thank you
Have a nice day
Jan 25, 2011 | Computers & Internet
Motor car electrical fault
ok....the problem is the rear washer pipe has blown of in the tailgate where it connects to the motor,it happens when you operate the rear washer when it is frozen.the connection is fairly weak and cant cope with pressure build up.in both cases you need to remove the tailgate trim,reconect the pipe and dry out the catch as that has a micro switch in it that operates the warning light for tailgate open and the alarm.it is shorted out with water hence the false alarming and warning light on........if you pop the bonnet but dont open it that will stop alarm from arming as temp fix,but dont forget to shut it before you drive off .hope this helps,please rate this ,thx
Feb 09, 2009 | Volkswagen GT Cars & Trucks
Compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Jun 22, 2008 | Coleman Mach III Air Conditioner
Dvd/cd drive
remember only one can burn at a time
Jan 12, 2008 | Intel Everex LM7WE Notebook
Pc is not starting up
I'm sorry to tell you but your cpu has probably fried. Your pc hanging a lot probably meant something was overheating and the fact that you say your cpu is not hot when you have the cooling fan off of it means it is probably the cpu. When you first turn your system on without a cpu cooling fan, the cpu should be slightly warm, although I do not recommended running a cpu at all without a cooling fan or even touching it when it has power.
Aug 18, 2007 | Intel Pentium 4 1.7G, 1.7 GHz...
Acer Aspire E500 PC Desktop Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
