Question about LG L1717S-BN 17" LCD Monitor
LG1717S - Power light flashing - no image.
Since about two weeks ago my monitor power light started flashing when I turned the PC on, but the screen remained blank. Eventually, after about 3mins, I would get a blue Flatron logo, and then it would come on to the windows log-in screen. The other day this got worse, and went to the Flatron logo, then back to blinking, then the logo, several times, then it eventually came on. But now it's refusing to come on, I left it blinking for at least 6 hours. Ive tried un-plugging and re-plugging everything and pressing the power button on the monitor, but no success.
Is my monitor dead or is there a simple solution to this ?!
Cheers,
Dave.
  • vozv Nov 27, 2008
    I have the same exact problem. First i ignored it, but now I'm sitting in front of black monitor and trying to find the solution on friends laptop.
  • LG Master
  • 19,396 Answers
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
I have a Samsung SyncMaster 172n monitor and the screen stays black when I turn the power on. The power light starts flashing about 3 seconds after I turn it on. All the power cords are plugged in, the...
When the monitor starts up you should be able to see the Samsung screen logo, if not it does point to the monitor. But lets be sure! hook a spare monitor to the computer, if it is okay! the Samsung Monitor is the problem and is not cost effective to repair, cheaper to replace. Now if both screens show the same problem, this indicates the Video Graphics Card in the computer is the culprit.
Jan 19, 2011 | Samsung SyncMaster 172N 17" LCD Monitor
I have 2 monitors connected to 1 computer using a
satservice, What happens AFTER 15 min of FLASHING?? What did unit do or act like 3-4 weeks ago? Is the screen both BLACK and BLANK? or is screen just black and you can SEE win-desktop if you shine a bright flashlight 1 inch from screen at differnt angles? Can you use your Samsung warranty? Will monitor do same when connected to different KNOWN GOOD prebooted to desktop PC? Are you refering to the "power ON" indicator light on front BEZEL as the FLASHING thing? Need more info, but I suspect "shutdown of units "switch-mode-power-supply" due to detection of FAULT CONDITION having been detected with other circuit or with itself. Read some of my other responses in my fixya profile that deal with BLACK SCREEN repair. If this response useful, rate on fixya. 12fixlouie
Dec 19, 2009 | Samsung Computers & Internet
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    Monitor Goes black, or flickers on and off
    The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
    Check out LCD parts for parts, service and DIY info. use this link :-
    www.lcdparts.net
    Aug 29, 2009 | ViewSonic OptiQuest Monitor
    Flickering, jittery image, white horizontal flashing lines
    this is real old right
    no photo off i messing up, how can we guess, what you see?
    amazing....
    my guess power pack shot.
    i guess you cant barrow a monitor and try that?
    2nd guess blind, the back light failing
    or is damage if it was hit, the LCD will have damage
    gently flex the frame goes nuts, bingo.
    Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
    LG L1717S-BN 17" LCD Monitor Logo
    1,062 people viewed this question
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
