Question about Amana ALG331RAW Gas Dryer
Amana gas dryer
Can't find the pilot light on a 10 year old model
  • 71 Answers
There is no pilot it has an ignitor bar that glows when it lights the gas.
Posted on Dec 20, 2008
It wont heat
never heard of having a pilot light as well an ignitor, the two don't go together. If your have a pilot light that is on the unit is getting gas. If there is pilot light there is usually a knob to switch between pilot light, off, and active on. maybe set to pilot light only.
Nov 09, 2013 | Amana ALG331RAW Gas Dryer
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
Dryer is not heating enough to dry the clothes. It is 9 years old, is it better to just invest in a new dryer?
After 9 years you are going to need to replace some parts. If the ignitor works and the flame sensor is shutting down the gas but the flame stops after a while or not at all then them cols need to be replaced. themobilian_2331.jpgthemobilian_2332.jpgthemobilian_2333.jpg
Amana Dryer Service Manual Gas and electric models (printable)
May 09, 2011 | Amana ALG230RAW Gas Dryer
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
Gas dryer pilot? or electric starter.
If you can send me the model number that is on the front panel just inside the door I can tell you for sure what kind of ignition it has. If it is newer than 20 years old it is most likely a hot surface or glow bar ignition and does not require lighting.
May 02, 2010 | Dryers
Is there a pilot light on amana gas dryer model LG4309W
There is no standing pilot light. The gas is ignited by a hot surface device that is electrically controlled. Trace the exhaust venting to locate the burner area.
Sep 08, 2009 | Dryers
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Amana Gas Dryer Model LG44097 suddenly quit heating. Can I correctly assume the problem is the Fabric Selection knob, part PS2201078 that controls heat/no heat?
probably not as these rarely go. More likely is that the glow bar ignitor on the gas valve has failed. Unlike old gas models, today's dryers do not use a standing pilot but a glow ignitor. This is the weakest link in the system. Part number fsp-279311
Apr 09, 2009 | Dryers
1317150009709 frigidaire dryer0how do i get at the pilot light or
There are 2 house fuses in the dryer circuit. If
1 of the 2 fuses is blown, the drum may turn
but the heater will not operate.
Gas supply valve is not open (gas models).
Dryer does not have anough air supply to
support the burner flame (gas models).
LP gas supply tank is empty or there has been
a utility interruption of natural gas (gas
models).Replace fuse.
Check to make sure supply valve is open. See INSTALLATION
INSTRUCTIONS for procedure.
See INSTALLATION INSTRUCTIONS.
Refill or replace tank.
Dryer should heat when utility service is restored
Feb 16, 2009 | Frigidaire FGQ332ES Gas Dryer
Gas dryer
First, let me be sure that you have a pilot light on this dryer. Most dryers (even the older ones) use an electric ignitor to ignite the gas flow. This ignitor will glow red or orange, and a flame sensor will start the flow. If you are not sure that you have a pilot light, try starting it a couple of times and let it run for about 30 minutes. These units sometimes get air in the lines (especially if they were opened for repair) and the air has to get purged from the system before it will light completely. Let me know for sure about the pilot sysem, because they are so very old, you usually cant get parts for them anymore. Thanks!!!
Jan 24, 2008 | Dryers
Amana ALG331RAW Gas Dryer Logo
267 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
