Question about HP DeskJet F380 All-In-One Printer
THE PRINTER IS NOT COMPATIBLE WITH WINDOWS VISTA
I tried installing the hp deskjetF380 but the installation fails to proceed
  • dgoodwin Sep 08, 2008
    Message reads unable to connect
  • Anonymous Sep 17, 2008
    COMPUTADOR COM WINDOWS VISTA NãO ACEITA IMPRESSORA HP F-380 ALL-IN-ONE
U must have the vista driver from www.hp.com
Posted on Sep 08, 2008
    Novelist:
  • 158 Answers
Go to: http://welcome.hp.com, to find updated drivers you can download.
Printer installer not compatible with the OS. i need one compatible to windows vista. HP psc 1210 all-in-one
You download to the internet for the driver with the window vista compatible installer.. Just type HP psc 1210 driver download then click search. Select and click the website that have an available program for that printer.
Oct 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Vista wont allow me install the hp 6500 printer disc
I think your CD Software Installer is only Windows XP System.
Try to download Windows VISTA HP6500.
www.yboyandrei.com
Oct 01, 2009 | Office Equipment & Supplies
I have windows 7 evaluation copy and it wont install my c3180 printer, help!!!
Windows 7 is almost like Windows Vista. Hence if you printer is Vista compatible, try to install the printer using Vista drivers
Aug 27, 2009 | Office Equipment & Supplies
Hp deskjet 9650 not compatible with Vista 64-bit
Hp Deskjet 9650 printer owner, sorry to inform that there is no Microsoft Windows Vista operating system printer driver solution available for your printer. But there is an alternative way to workaround it so that you can do basic printing with your printer.
As a workaround, an alternate printer driver solution included in Microsoft Windows Vista operating system can be used to perform basic printing to the printer. However you might find that some of the product features are no longer available when using this alternate printer driver, but that is your best option right now.
The alternative HP printer driver that will work with your printer is HP Deskjet 9800.
The Next thing you do is: Install the driver for HP deskjet 9800
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click Start , click Settings , and then click Printers .
3. Click Add a printer .
4. Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver for the printer (deskjet 9800) and then click Next .
9. In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of the printer, if desired.
10. After the screen stating that the printer was successfully added displays, connect the USB cable / Parallel cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
12. For USB connected printer, please proceed to step three . For Parallel port connected printer, please proceed to step four .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Next is: Configure the printer
1. In the printer folder, right-click on the name of the printer and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to the newly created USB port, click Apply .
Last step: Print a test page
1. Click the General tab.
2. Click Print Test Page .
Good luck Cheers!!!
Apr 26, 2009 | HP DESKJET PRINTER, HP OR COMPATIBLE
Printers
Your equipment is Vista Compatible and you can get the latest drivers here.
Best regards
Nov 01, 2008 | HP DeskJet F380 All-In-One Printer
Cannot install printer in windows vista.
Is your printer Vista compatible?
Did you have been installed in correct way your printer?
If this it is a driver issue, try to find the right drivers for your printer (must be compatible with Vista)
Go to the website of your printer manufacturer >> www.yourprinterbrand.com >> then go to Support >> Software and drivers
And download the driver there
If your printer is not Vista compatible at this point:
1) is better to get a new printer compatible with Vista
or
2) Downgrade your OS to one compatible with your printer.
Let me know how your issue it is going....
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 16, 2008 | HP PhotoSmart C4180 All-in-One Color...
My windows vista wont let me install my HP Photosmart C4180 printer
Make sure you have the correct version of the software compatible with Vista. It could be that the driver you are trying to install is for a different OS.
Go to this page and download the latest software compatible with Vista for your printer.
Hope that helps!
Sep 27, 2008 | HP Computers & Internet
Installing HP Officejet 5600 all-in-one in Windows Vista
Go to hp.com. Click on 'software and driver downloads' (on the left of the screen). Next to 'for product:' type in Officejet 5600' and click the >> symbol. Then choose from the list that comes up. When in doubt, choose the first on the list, HP 5605 All-In-One. On the next screen select 'software and driver downloads' again. There you'll see where you can select Windows Vista. CLick on that and sleect, under "Driver", HP Full Feature Software and Drivers.
On the next screen, scroll down and select 'Install Now'.
Best wishes, Al
Mar 08, 2008 | HP Officejet 5610 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
48 people viewed this question
Ben Johnson
