Danby DDW1899WP Portable Dishwasher Logo
Posted on May 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a brand new Danby ddw1899wp dishwasher about 2 months ago. It has worked great until recently. Whenever the dishwasher drains water through the hose, it makes a noise like something is stuck and/or rattling around. Since hearing this noise, I immediately stopped using my dishwasher. I have, since then, tried to run a cycle without any dishes in hopes it would go away. Sadly it did not. Like I said, the noise only happens when the water drains from the dishwasher. Thanks!
Dan Apthorp
Level 3:
  • Danby Master 2,824 Answers
  • Posted on May 30, 2017
Dan Apthorp
Danby Master
Level 3:
Answers
2824
Questions
0
Helped
888991
Points
7391
If it's only two months old I would talk to the place I bought it from. I am sure they will help you. It should be under warranty.
5 Related Answers
Anonymous
  • Posted on Jan 18, 2009
SOURCE: my danby countertop dishwasher won't drain
the problem has not been resolved. does not drain.
Anonymous
  • 43501 Answers
  • Posted on Jul 12, 2010
SOURCE: Danby DDW399W dishwasher - drainage and spin arm problems
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Anonymous
  • Posted on Dec 16, 2010
SOURCE: what is the funnel thing
The "funnel thing" is exactly what it looks like- a funnel. It's for adding the salt to the water softener located on the "floor" of the dishwasher:)
caroldon
  • 17130 Answers
  • Posted on Nov 05, 2011
SOURCE: i have a ddw1899wp danby i have a green power
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Anonymous
  • Posted on Dec 15, 2011
SOURCE: Danby Dishwasher DDW1806BSL Dishes weren't getting
Fault Codes E3: Longer heating time, but required temp not met.
Possible Causes: Malfunction of temp sensor or heating element.
Danby DDW1899WP Portable Dishwasher will no longer turn on
If it just has no water, then it would be a fairly safe bet it was the water inlet valve. If it is completely unresponsive, that points to either a power issue or a control board issue. You will need a Service Technician, and you may be better off with a new one depending on the age of it. The reviews put it at about 3 years old and $429. It is more of a freestanding machine that portable, it just has wheels. It looks useful.
https://www.google.com/search?q=Danby+DDW1899WP+reviews
DDW1899WP-1 ' Danby 8 Place Setting Dishwasher ' EN ...
https://www.danby.com > products > kitchen-en-us > d...
Description. Washing dishes has never been as much fun as it is with this versatile dishwasher by Danby. This attractive machine comes with a silverware basket, ...
Dishwasher doesn't wash. Only fills and drains.
Wash pump went out. Drain pump still works.
Not enough water. Improper water fill.
1helpful
I need a manual for a Danby Model DDW1899WP-1 portable dishwasher
Danby has the manual for the DDW1899WP-1 on the product information site: https://www.danby.com/en-us/products/kitchen-en-us/ddw1899wp-1/ . Look in the right hand column as you scroll down. The direct link to the Owner's Manual is currently: https://www.danby.com/wp-content/uploads/2016/04/DDW1899WP-1_EFOM_201504212.pdf .
I hope this helps.
1helpful
Water softener
Marsena, I am at the point where I'm going to call a repairman. I'm very disappointed that I have a brand new appliance, and no means of having this issue handled. This is a great dishwasher otherwise, but I could not recommend it due to this problem.
3helpful
2answers
Salt water error message when I have a water softener already
I feed Danby dishwasher salt whenever he asks (buy it by the case online). Still produces marginally clean dishes.
6helpful
What is the funnel thing that came with my dishwasher danby ddw1899WP?
2helpful
I have a water-softener dispenser in my Danby 1899 W Portable diswasher. I do not know how to fill the dispenser and I cannot run the dishwasher until this is resolved. The user manual provides no...
I couldn't find it either for a long time:
1) Pull out the bottom rack as if you were putting dishes there
2) Look at the bottom of the dishwasher and there will be a white circle (near the upper left side) where you can add the water softener.
I didn't use any for a while and the dishwasher worked great so I'm not sure why you can't run it.
1helpful
What does E3 mean?
E3 not hot enough. This defect can be caused by, but not only, a defective element or clogged spray arms.
Sep 29, 2017 • Dishwashers
Top Danby Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
