Usually the wiring diagram for the motor is shown on the motor nameplate or inside the motor end cover. Unfortunately the diagram is not in the owners manual but this document should be read because it provides safety information. For this motor running at 110VAC, the manual recommends using 10 gauge wiring. Most pumps are wired using 12 gauge wires. Also, if a 20A breaker trips then a higher breaker may need to be used. If you are making wire or breaker changes then you need to have an electrician do the job. I hope this help.
