Question about Mercury Computers & Internet
PI865GM Memory issue
Hi All,
I have a Mercury PI865GM Mother board.I have installed two modules of 1GB 400MHz RAM modules. But my system detects them as 333Mhz. How do I make my computer to recognize them as 400MHz. I know there is a jumper setting I need to change....but I lost my manual, hence do not know which jumper to change.
Please help.
Nagesh R
  • 236 Answers
I cannot find anything in your motherboard manual about a jumper setting to change the RAM frequency. However, the only thing I can find is on the CPU PnP Setup Page in the CMOS setup utility that says DRAM Frequency (currently set to auto).. Perhaps you can try changing this to 400MHZ (if the option is available).
There may be a jumper setting somewhere, but without a proper photo of the motherboard, or a better manual, I cannot find it...
Posted on Sep 04, 2008
1GB DDR 400MHz CL1.8, HYMD564M646CP6-J AA (NYNIX KOREA01 PC3200U-25330)will supported by mercury pi945 gvm-agp mother board
Memory• 2 x 240-pin DDR2 DIMM sockets support upto 2GB (DDR2 667/533/400)
• Maximum: 2GB
only supports DDR2 memory.
Does not support DDR 400.
Mar 01, 2012 | Mercury PVCLE266 Motherboard
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
Does ''FOXCONN 8657MF-series'' supports 400mhz fsb of RAM
Yes, you can add it. The faster 1 GB will be downclocked to the speed of the slower 256MB.
 But it would be better for performance to remove the 256 MB one completely.
May 05, 2010 | Foxconn Computers & Internet
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
On intel d102ggc2 one ram of 1gb detect but alongwith 512mb does not detect
PLUG BOTH THE MEMORY MODULES AND THEN OPEN THE BIOS SETUP CHECK IF BOTH OF THEM SHOW UP IN THE MENU IF YES THEN SAVE THE BIOS SETTINGS AND RESTART THE COMPUTER OR ELSE MAKE SURE BOTH THE MEMORY MODULES HAVE SAME FREQUENCY
Jul 09, 2009 | Intel D102GGC2 Motherboard
HOW TO FIND RAM CAPACITY OF INTEL D102GGC2
Intel D102GGC2 Motherboard Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
Maximum Memory Capacity: 2048MB
* Currently Installed Memory: 512mb Number of Banks: 2
* Dual Channel Support: Yes
* CPU Manufacturer: GenuineIntel
* Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
Your MotherBoard Supports up to 2GB of memory.
You have 512mb, you can add 512mb to the empty slot.
, however,It's a good idea to keep them the same if you can.
You can install memory that is: DDR2 PC2-5300 (PC2-5300 is 667Mhz) you can use 1gb memory in each module for best performance and matching pairs since your motherborad supports dual channel.you can use sound card and SATA hard disk for higher disk support
Mar 15, 2009 | Intel D102GGC2 Motherboard
Memory problem on startup?
Well, according to your manual, Long beeps in a endless loop mean no DRAM was installed or detected. What type of RAM are you using? The problem is with your RAM only. if the frequency of your RAM doesn't matches your motharboard then it will not work. The frequency of RAM varies from 233MHz, 333MHz, 400MHz, 667MHz, 800MHz, 1033MHz etc.. and also it varies from motherboard to motherboard.
Thank you.....
Jan 29, 2009 | ASUS P4XP-X Motherboard
Mercury PI865GM memory problem
Dear Nagesh,
Its not a big issue, all Higher Frequency Rams comes with Backward compatibility, but this compatibility works with only branded Rams.
Regards
Sep 03, 2008 | Computers & Internet
Ram upgradation for 845glad mother board
Hi! If you have orignal Intel D845 then you need ram less than 333 Mhz (Around 266mhz or so) and do remember to check that it is advisable not to use RAM of more than 1GB as you won't be able to find a 1GB RAM(DDR1) with 266 Mhz or less.
May 16, 2008 | Intel Motherboard
SAMSUNG 1GB RAM 400MHZ PC3200
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
Or
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
93 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
