Pls help me solve
Find the LCM by listing the multiples
1. 21 =
10 =
LCM =
2. 15 =
45 =
LCM =
3. 10 =
8 =
LCM =
4. 45 =
60 =
LCM =
5. 25 =
15 =
LCM =
The way to solve it is by checking sound and audio devices and if you check the back of your monitor there is three colours pink green and blue make sure its plugged in the right one. if you have done that it should be enabled to let the sound out.
Posted on Sep 03, 2008
The way to solve
I need help with greatest common multiples i am haveing troubles
Understand the process first and then go for an example:
How to do?
1. Make a list of multiples for each number
2. Continue your list until at least two multiples are common to all lists
3. Identify the common multiples
example_ find common multiples for two numbers_ 10 and 25-hw01nkm5y1qvuh0mvcthmqik-1-2.png Still have confusion? Consult an expert Algebra Tutor!
Sep 19, 2017 | Office Equipment & Supplies
2000 lincoln town car light control module wiring diagrams
You don't need a wiring diagram ,what you need is a scan tool that will pull codes from the LCM , an LCM Parameter Identification (PID) Index ! Checking codes first !
LCM Diagnostic Trouble Code (DTC) Index DTC Description DTC Caused By Action B1312 Lamp Headlamp Input-Short to B+ LCM REFER to Section 417-01 . B1334 Decklid Ajar-Short to Gnd LCM REFER to Section 501-14B . B1340 ESC Tone Input Request Short to Ground LCM REFER to Section 501-14B . B1342 ECU-Defective LCM REPLACE the LCM. REFER to Section 419-10 . TEST the system for normal operation. B1352 Ignition Key-In-Ckt Failure LCM GO to Pinpoint Test C . B1359 Ignition Run/Acc Circuit Failure LCM REFER to Section 211-05 . B1462 Seat Belt SW_Ckt Failure LCM GO to Pinpoint Test B . B1485 Brake Pedal Input Circuit Short to Batt. LCM REFER to Section 417-01 . B1555 Ignition Run/Start Circuit Failure LCM REFER to Section 211-05 . B1569 High-Beam-Short to B+ LCM REFER to Section 417-01 . B1577 Park Lamp Input-Short to B+ LCM REFER to Section 417-01 . B1581 Panel Dim Increase Input Circuit Short to B+ LCM REFER to Section 413-00 . B1585 Dim Panel Decrease Input Circuit Short to B+ LCM REFER to Section 413-00 . B1676 Battery Voltage Out of Range LCM REFER to Section 414-00 . B1687 Dome Lamp Input Short to B+ LCM GO to Pinpoint Test D . B1689 Autolamp Delay Input Circuit Failure LCM REFER to Section 417-01 . B1691 Autolamp Delay Input Circuit Short to B+ LCM REFER to Section 417-01 . B1695 Autolamp ON/OFF Short to B+ LCM REFER to Section 417-01 . B1873 Turn Signal/Hazard Power Feed Short to Ground LCM REFER to Section 417-01 .
Aug 12, 2016 | 2000 Lincoln Town Car
Iwhere is the turn signal flasher located
  1. CAUTION: Prior to removal of module, it is necessary to upload module configuration information to a scan tool. This information needs to be downloaded into the new module once installed. For additional information; refer to Module Configuration. Ignore numbering on left of page
  2. There isn't a flasher...It is a module called the LCM ( Lighting Control module)...It needs to be replaced and requires a scan tool...Not a backyard project...
  3. Disconnect the battery ground cable.
  1. Remove the LH instrument panel lower insulator.
    1. Remove the pin-type retainers.
    1. Disconnect the courtesy lamp.
    1. Remove the LH instrument panel insulator.
  1. Position the LCM aside.
    1. Remove the screws.
    1. Release the locking tab.
  1. Remove the LCM.
    1. Disconnect the electrical connectors.
    1. Remove the LCM.
iwhere-turn-signal-flasher-located-wtik1u3pjfqjepqdinj1lpkj-5-5.gif saailer
Jun 19, 2015 | 2000 Mercury Grand Marquis
I try to find LCM but keep getting error
I do not think that the FX115ES can give you the prime factor decomposition of a number. The FX115ES Plus may do it.
On the FX991 ES Plus there is key marked FACT.. It is the one between the Change sign key (-) and the HYPerbolic key.
I am afraid you will have to do the decomposition of the two numbers by hand. For example
1440=(2^5)(3^2)(5)
700=(2^2)(5^2)(7)
By multiplying the two number you can get a multiple of both but it won't be the smallest.
What you do is scan the two decompositions to identify the various prime factors, 2,3,5, 7
All those factors must be present in the LCM. For each prime factor, select the largest exponent . This is going to be 5 for factor 2, 2 for factor 3, 2 for factor 5, and 1 for factor 7
Hence LCM(1440,700)= (2^5)(3^2)(5^2)(7^1)=50400
Verify that 50400/1440=35 and 50400/700=72
Sep 22, 2014 | Casio FX-115ES Scientific Calculator
Replace dimmer switch
The headlamps ( high an low ) are controlled by the LCM lamp control module .
Headlamp Dimmer Switch
Under the left side of the IP, on the base of the steering column
Headlights Circuit Description (Buick)
Battery positive voltage (B+) is supplied at all times to the lamp control module (LCM) through the LH underhood fuse block LCM/HDLP circuit breaker via CKT 242 (RED). When the headlamp switch is placed in the ON position, the headlamp switch input to the LCM is grounded via CKT 103 (WHT). The LCM then supplies battery positive voltage (B+) via CKT 12 (TAN) to the following components:
• Left low beam headlamp
• Right low beam headlamp
When the headlamp dimmer switch is placed in the HIGH position, the LCM removes battery positive voltage (B+) from the low beam headlamps. The LCM supplies battery positive voltage (B+) via CKT 11 (LT GRN) to the following components:
• Left high beam headlamp
• Right high beam headlamp
The LCM provides battery positive voltage (B+) to the appropriate headlamps under the following conditions:
• The ignition switch is in the RUN position.
• The ambient light sensor indicates darkness.
The lamp control module (LCM) monitors the ambient light conditions through the ambient light sensor. The ambient light sensor is a variable resistor whose resistance changes as the surrounding ambient light level changes. As the ambient light decreases, the resistance of the ambient light sensor increases. The LCM measures the resistance across the ambient light sensor and determines whether it is day or night.
Search from over 10 Million Auto Parts
Do you know how to test automotive electrical circuits ? Check power in an power out . Videos on youtube on basic automotive electrical testing .
Mar 08, 2017 | Buick LeSabre Cars & Trucks
Casio fx-115es plus how to find the LCM
I have a fx-570ES plus instead but one easy way I found to calculate the LCM us by adding 2 fractions in the following format: 1/a + 1/b, where a and b are the numbers you are calculating the LCM for. In my calculator the result is displayed as a fraction, with the denominator being the LCM. From there I can also figure out the HCF with the following formula: HCF=(a * b) / LCM. In some calculators the fraction might get displayed in decimal format but most of the newer ones can switch between fraction and decimal format. I hope this helps.
Jun 11, 2012 | Casio Office Equipment & Supplies
Where is the GCF/GCD button on my TI-85 Plus Silver Edition
There are no such buttons, You'll find the lcm (least common multiple) and gcd (greatest common divisor) functions in the MATH NUM menu. Press MATH, right-arrow, and select the desired function.
Jul 07, 2011 | Texas Instruments TI-84 Plus Silver...
Lights on 2000 Mercury Grand marquis will suddenly go out while
please rate as solved if this fixes your issue. Let me know too.
I believe you have a bad LCM, Lighting Control Module. Or, the connectors to it have corrosion maybe. The module is above the brake pedal. It is very expensive. You can buy one at discount from tascafordparts.com. Sometimes, ebay has one too. But, you need one for your year car. Match the part number on your LCM.
Here's how to get it out.
SECTION 419-10: Multifunction Electronic Control Modules 2000 Crown Victoria/Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Module —Lighting Control (LCM) Removal
  1. sya~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Prior to removal of module, it is necessary to upload module configuration information to a scan tool. This information needs to be downloaded into the new module once installed. For additional information; refer to Section 418-01 . (I replaced one without doing any programming, so I don't think this applies).
  1. sya~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
  1. Remove the LCM.
    1. Remove the LCM.
Jun 03, 2009 | 2000 Mercury Grand Marquis
80gb ipod classic won't turn on!
sounds like you have an error on your hard drive. Either fomat your hard drive in FAT32 or replace it for a new one.
Aug 20, 2008 | Apple iPod classic MP3 Player
126 people viewed this question
 Grubhead
Grubhead
