Question about Panasonic Workio DP-2330 Printer
Fax number the fax number that prints at the top of a fax going out needs to be changed as the machine has changed locations - cannotfigure out how to do this
    Sergeant:
  • 284 Answers
Press the fax button, the function-7-1-start- and keep hitting start till you see the number you want to change
Posted on Sep 22, 2008
How can i chanche de fax number dat is printed. That number is not good, i wil chanche this
you need to go into the menu and look for settings fax the n look for the fax ID here you can change the number and the header the header is the name you want printed on top of the page ie your company name.. you can find the sections by looking on the right hand side of the display and you should see a button called reports here you can print off the section rep[ort which tells you where to find the settings in teh menu
Sep 29, 2009 | Canon FAX-L350 Plain Paper Laser
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Our 2920 bother fax machine still has our old fax number on all printed paperwork. Could you please advise how we can change this to our current number? Thanks Lucy
You can change the Fax ID in the menu. It should be located in Menu/Set 0,3 (Station ID). Enter your new fax number, menu/set, new phone number, menu/set, your "name", menu/set. And you're set.
Jun 03, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
Printing wrong fax number on paper headings
HI
Cant find a manual for that model but this is close enough for changing the details i think.
Download it from here
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/IMAGERUNNER%202025I-_E
Feb 16, 2009 | Canon imageRUNNER 3035 Black and White...
Cannot delete old quick dial numbers
quick dial numbers cannot be deleted.you just have to make sure you print first the auto dial list for you to know where it is located.go to that location,enter zeros and then menu/set to save the number as a zero
Nov 05, 2008 | Brother IntelliFax-2820 Laser Fax
WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
Hope this helps.
  1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
Jul 23, 2008 | Xerox Office Equipment & Supplies
Printing a report
Funtion #7, userparameters, go down in the menu, you will find the wrong number there and can correct it.
Jul 17, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Change phone number on fax
FAX PRINTS OUT OLD PHONE NUMBER. FAX NEEDS TO REFLECT NEW PHONE NUMBER ON SENDING HEADER OF FAX
Apr 18, 2007 | Muratec F360 Plain Paper Laser Fax
Sender Id
Sender ID ecblank.gif ecblank.gif dot.gif ecblank.gif This is a descriptive title that identifies the sender -- usually the location of your fax machine or the name of your company or office. It is printed at the top of every fax you send. You can enter up to 32 characters. The first 16 characters will also be used as your Personal ID, which may appear on the displays or reports of other fax machines you are communicating with
Setting the TSI/CSI and Sender ID ecblank.gif ecblank.gif dot.gif ecblank.gif1 Press Menu/Exit to enter the menu.
2 Input speed access number 02. 3 Input up to 20 numbers and characters (0-9/Hyphen/ Space/+), press Enter. 4 Press Menu/Exit.
Sep 27, 2006 | OKIFAX 5950 Plain Paper LED Fax
Panasonic Workio DP-2330 Printer Logo
54 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
