Question about NEC MobilePro 780 Pocket PC
Software on the MobilePro system to connect to a Windows Terminal Server
Do I need to install any software on the MobilePro system to connect to a Windows Terminal Server?
    Master:
  • 903 Answers
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Posted on Sep 14, 2005
Dear experts; We have a HP R3000xr UPS, inetend to install the power management software on a server runs windows server 2008 R2 OS. Installed the power manager server software, the following messages...
Is the cable USB or SERIAL?
make sure serial port IRQ is enabled in BIOS
ALso make sure you are using x64 and not x32 drivers for UPS
ALso try getting a USB cable to connect to your UPS device
Feb 17, 2011 | HP R3000 UPS System
Setting up Terminal Services on Server 2003 at the head office of a client in a workgroup environment, no Domain Controller. The branch office wants to log in through a VPN Router ( Linksys RV042 that has...
Assuming you can connect via Remote Desktop without any issues...
Printing through Terminal services requires that printing be enabled in the Terminal Services Configuration (Client Settings Tab). It also requires that the printer driver be installed on the Terminal server, not the actual printer (as it shows under the control panel) but just the driver. You can install just the driver by going to File/Server Properties under Printers and Faxes ON THE TERMINAL. Install the printer normally on the client machines.
Note: For a printer to work via Terminal services it needs to have a compatible driver (which I believe is called PCL??) So some consumer printers (the ones that only come with Setup programs, not just driver packages) will not work. The majority of HP Officejets and laserjets are fine, as are Brother lasers.
Oct 27, 2009 | Microsoft Windows Server 2008 Terminal...
How to set up a network with 7 computers using a server with microsoft server 2003
You must need a router or a switch to connect each of your terminals to your server(Lan or Wifi), if you already install MS server software it will be easy, you must need to install client protocol in your terminals when plug to your swith MS software automatically detects and apply and "ip" address, this permit you to share files /printers or detect any other device in your switch. I recomend to use 10/100/1000 gigabit switch.
Thanks
Apr 28, 2009 | Microsoft Windows Server 2003 Enterprise...
Windows Server 2003 - How can I install Services remotely ?
In my opinion, using Windows Password Reset Software or free Ophcrack is the best method to reset Windows server 2008 password.
Windows Password Reset Software is such software that you can reset forgotten Windows password for Windows 7/XP/Vista by burned CD/DVD/USB. It is professionally designed to reset lost password with less time-consuming and 100% recovery guaranteed. Also it can reset windows password for Windows Server 2008/2003/2000.
If you want to get more information about Ophcrack, please login Ophcrack Official Website.
May 29, 2008 | Microsoft Windows Server Standard 2003 for...
Howto add a network printer on Wyse winterm S30 terminal?
The S30 terminal has the CE 5.0 operating system loaded as default. So you are limited by the operating system and not the hardware when it comes to network printing.
Here is a extract of the release notes for Windows CE 5.0:
"In Windows CE, TCP/IP supports network printing through the Server Message Block (SMB) protocol. It does not provide the Windows Line Printer Remote (LPR) Spooler. However, independent software vendors (ISVs) and original equipment manufacturers (OEMs) can add this support."
In short, you need a 3rd party software program or a (SMB) printer server setup to setup network printing on the S30 terminal..
Wyse also have add-on software to help, if you have CE 5.0 loaded then try the "Thinprint" add-on supplied as a free download by them.
Download Link:
http://www.wyse.com/supportdownload/3series/Addon_ThinPrint_B0010.exe
I haven't tried this, so let me know if it works.
May 02, 2008 | WYSE Winterm S30 Network Terminal
Terminal server not responding
Are you receiving errors in the "event viewer"? And if you are what are they?
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Oct 20, 2007 | Computers & Internet
Connect to a Windows Terminal Server
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Windows NT server using RDP client
To resolve this issue download the MobilePro Service Pack 1 and install it on your system: ftp://ftp.necsam.com/pub/Catalog/3959/MobileProSP1.asp
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Sep 14, 2005 | NEC MobilePro 880
NEC MobilePro 780 Pocket PC Logo
213 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
