TV turns on but no picture - Televison & Video
  • suhasranadiv Sep 03, 2008
    LG REAR PROJECTION TV MODEL NO: 52SZ8R-TB, POWER TURNS ON, POWER LIGHT BLINKS GREEN AND THERE IS NO PICTURE
    Master:
  • 521 Answers
The bulb is the culprit according to me.replacing the bulb should solve the problem, hope it helps. thanks
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 03, 2008
    Sergeant:
  • 336 Answers
First bit of advice is to Turn on your projector and check the bulb and make sure that it has not burned out. Next if you have determined that it is not the bulb, I will continue t see what I an do. Also how lonng have you had your TV? If you determin that it is the bulb you can purchase a replacement from the website below.
All The Best,
RCF
http://www.purelandsupply.com/LG-Zenith-DLP-Lamp.html
    Master:
  • 763 Answers
There is a resistor on the CRT board that goes bad sometimes. If you have a multimeter, you can check the resistors if you know how the color coding works on these resistors. If you do not, take the set to a repair shop, as this problem, if this is the problem, should not cost that much to replace a 10 cent resistor.
OR try this one
Things You’ll Need:
  • Owner's manual
  • Tools
Step1 Consult your TV’s troubleshooting guide. Follow its recommended steps. Most problems can be fixed by troubleshooting.
Step2
Diagnose what's wrong with your TV. There are many TV repair tip websites on the Internet you can consult, like the "Notes on the Troubleshooting and Repair of Television Sets" website
Step3
Get your TV’s service manual to find a diagram of your TV’s circuits. You can get a service manual through a retailer that sells your TV brand or through an online store like tvdiagrams.com
Step4
Gather the necessary tools. For most projections TVs you'll need a Phillips head and a flathead screwdriver to remove the back shell. You may also need a digital multimeter to test the circuits.
Step5
Know the common problems and fixes for a projection TV.
Step6 Unplug your TV’s power cord from the electrical outlet and disconnect any peripheral devices like a DVD player or cable box. Place your television screen-down on a soft surface.
Step7 Remove the screws that connect the back shell to the rest of the TV. Then pull the shell up and off the TV carefully. Set it aside.
Step8 Consult your TV’s service manual to find the part that you need to replace or repair.
Step9 Place the shell back on the TV once your repairs are finished. Replace each screw to secure the shell to the TV.
Step10 Plug your power cord back into the electrical outlet and test your TV. If your repairs weren't successful, it may be time to consult a professional.
Tips & Warnings
  • Work in a spacious, dry and well-ventilated area. This will give you room to work, avoid the possibility of electrocution and help remove any fumes that are created during the repair process.
  • There are many TV repair guides online. Make sure the guide you use is applicable to your type of TV.
  • Unless you have at least a basic knowledge of electronics, don't try to repair a TV on your own. You may damage your TV further or injure yourself.
  • Electrical charges can stay in cords and circuits even after being removed from their power source. Always use rubber gloves to avoid electrocution.
hope that helps!
cheers
CHARCOIS
  • Charris Suaybaguio
    Charris Suaybaguio Sep 03, 2008
    by the way if your tv has a fuse then try to replace it too with a new one.
  • 4,234 Answers
I'm sorry, but there is littel help we can provide without the make and model number. There are numerous reasons for no picture. Can you please provide some additional details? For example, is there any blinking of a stanby light? Do you hear the high voltage startup (snapping like sound)?
Thanks,
Dan
  • ABRsvcs Sep 03, 2008
    Since this is a DLP machine, there is not CRT board. Please try replacing the lamp first. If you have the owner's manual, there should be a listing under the heading Troubleshooting that indicates what the blinking means. The most common cause of no picture for these is a bad lamp. The next most likely cause of the light engine. Since the lamp is the least expensive and the most common, check that first. Also, be sure that the fans is working and the area is clear of dust and dirt.
    Keep us posted.
    Dan
When I first turn on the TV the picture is messed up sometimes it shows a double picture.If I turn it on then off and back on again the picture is fine.Whats wrong? My second problem is that when I turn on...
Ur tv covergence board it is dying.Tv are developing a convergence picture problems.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it dying must require replacement like 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 30, 2011 | Mitsubishi WS-55819 55" Rear Projection...
When I turned the tv off last night the picture was fine, but this morning when we turned it on this morning, the picture is very dark and mostly blue. 51F59A, purchased in Dec 2006.\r\n Thanks for any...
If you turn the tv off for about 1020 seconds, turn it back on and see if you have a clear picture, if not it sound like a power supply problem in the tv. but if that did not solve the problem, the picture board on your tv is now malfunctioning or as gone bad, it means the picture board of your tv has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your tv to solve the problem.
Nov 28, 2010 | Hitachi Televison & Video
TV searches, but will not turn on.
Ur tv have problems,etheir the Tuner signal board or the LCD inverter board.After u turn on the tv,no picture turn tv off/on 3-4 times each time wait a few mins.see if the picture come on?Than it ur Tuner board have problems.If u turn on the tv and get just a flashes of a picture about 30 or 40 sec.than just disappear,than ur LCD inverter board is the problems it dead.
Apr 16, 2010 | LG 62SX4D 62" Television
TV Picture Pops In and Out Toshiba Color TV CZ27V51
mine was doing the same thing. If i put pressure on the cable input from left or right it would fix this.
May 22, 2009 | Toshiba CZ27V51 27" TV
Have picture lose picture tv turns off and on
the lamp has a life cicle. if yours is been used a lot. then the lamp has to be changed. when the tv cannot turn on steady and gets off imm. the computer inside the tv tries to turn off the set but the lamp charges again and the micro tends to keep working. the first step to take in this tv is to change the lamp to eliminate this common source of problems
Jan 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
