We have recently reset our zyair g-4100 v2 due to logging in probs, tried logging in several times to the ip address 192.168.1.1 with no luck. Have noticed however that when we click our zyxel icon, it takes me straight to the internet, on further investigation i could not find any software, driver etc for it, it has just vanished. I did go into start, command, prompt and ping the address, also with no luck.
Your help would be much appreciated. I am currently unable to check my emails so chat or a phone call would be most convenient.
Thank you and hope to hear from you soon.
SOURCE: Cant access the Zyxel IES-1000
Just a suggestion...try to loop-back ping to make sure YOUR still on the network. If you are have you tried tracert? The IES-1000 is an IP-based DSLAM, so you should get something back. Here is a link that may help you a bit more http://www.computerhope.com/issues/ch000444.htm
SOURCE: Serial number overlap after factory reset
There is a work around for this issue. The account logs can be sorted on date, which puts the latest entries on top of the pile, irrespective of the S/N.
SOURCE: The Zyxel router will allow me to 'Ping' from the
You should reset the router. or change setting by access the gateway
SOURCE: i cant log in to my zyxel!(zyxel ies 1248)
See the attached manual and look up page 42 where is shows how to reset your router to the default settings. The default ip is 192.168.1.1.
the link is: ftp://ftp.zyxel.com/P-660HW-D1_v2/user_guide/P-660HW-D1%20v2_3.40_Ed1.pdf
If this solves your problem, leave feedback please.
SOURCE: Hi! I tried to access to
Be sure that your router adress is 192.168.1.1 you can use winipcfg in windows (the gateway address is what you are looking for) to see if its the good adress.
http://support.microsoft.com/kb/141698
If its not working use another browser, simply restart the router or Hard Reset the router with a paper clip.
