Question about Philips Televison & Video
My Philips DTR210/05 keeps losing channels and sound. It will be tuned in and left while out at work, when I return all the channels are not there so I have to tune it in again. Then in the morning the same problem - I have to go through the whole installation process again! Also, sometimes once the installation process has completed, none of the channels have any audio!
Slinteriors
  • 8617 Answers
SOURCE: I have a philips tv
here is a link to the phillips universal remote page that has all the codes for any brand tv including phillips and it will explain how to program the remote try the codes for phillips one of the codes should work.
http://www.universal-remote.net/philipsmagnavox.html
Posted on Apr 08, 2008
SOURCE: old philips tv model no 21PT1532/05
this may be too late, but i had the same problem, then discovered that if you press the top of the volume up/down buttons together, the menu comes up. I was trying to solve another problem this way when I accidentally locked the TV. The instruction booklet tells me that you can only unlock it with the remote control, but that has long ago bit the dust. Does this mean that I'll never be able to turn it on again??!!
Posted on Jul 17, 2008
mistersony
  • 320 Answers
SOURCE: tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
Posted on Oct 18, 2008
SOURCE: Tuning a Channel
To Tune in Philips Machline TVs
Without using remote. Open panel on front of tv
1-- Press the menu key. --screen will now display 5 menu options--
2--press the down arrow key untill Install is highlighted
3--press the vol + key -- now install options appear (language--autotune---mantune--channel no--store)
4--press the down key to select the function required (Autotune is best) Manual is ok if the tv station's freq are known and they can be then given a ch no
5--press the + key to start the function selected ---tv will auto tune in tv stations when completed
6--press down arrow and highlite store then press ok
7--Press menu to clear menu off screen
Posted on Oct 29, 2008
jack_daniels
  • 304 Answers
SOURCE: tuning a philips remote to a philips tv
instructions on tuning a philips universal remote sbc ru 440 to a philips tv
Posted on Nov 23, 2008
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
Sharp aquos lc32l400x
It is a recommended practice to repeat the channel search routine periodically as the DTV environment is subject to change. Also, the antenna connection to your TV may not provide sufficient signal strength to maintain picture quality. Even weather can be a factor.
Jan 16, 2014 | Televison & Video
KDL-40V3000 program not tuning
if possable retune with a known working connection ie at the house next door
this will rule out your own setup and may save you time / money in the long run
May 15, 2012 | Sony BRAVIA KDL-40V3000 Television
Instructions to tune Philips tv 54cm colour TV. Search & store channelss
Hello
You haven't mentioned about the model number of your Philips TV. Different models have different type of tuning procedures. Any way I hereby send a procedure to set it autotuned. If it Doesn't work, please inform me through Fixya, stating your TVs model number also. ok
Press "Menu" on the remote control handset, and select the installation language.
Select a language and confirm it by pressing "OK" button on the remote control.
Press ' button to return to 'Instalation' menu.
Press "Menu" on the remote control handset and select Installtion > Preferences > Location.
Select 'Home" and press "ok" to confirm.
Press ' to come to the Installation menu.
TO TUNE CHANNELS AUTOMATICLY AND TO STORE
Press "Menu" on the remote control, "Select Installation" '>' Channels '>' Autoprogram '>' Start now.
Press "OK" and allow the start installation automatically.
If you run autoprogram when you have locked channels, a messege appears asking to enter your PIN code in order to complete instllation.
Try this, if doesn't work inform me with TVs model number. OK.
Nov 04, 2010 | Philips Televison & Video
My harmon kardon av amp keeps losing its memory/settings when its switched off, it also loses audio on the 3/2/1 on the aux, dvd channel, intermittent loss of volume help, too good a system to bin thanks
could be the memory chip, I used to see this a lot with Panasonic tv's that would lose all memory settings ie channel and tuning memory, with the intermittent vol problem it sounds like dry joints in the amp section, always check the components around the heatsinks for dry joints, especially capacitors and transisters, pay to get your hands on a service manual showing all the layout and different componets.
May 30, 2010 | Audio Players & Recorders
I bought a second hand philips tv 29ht2212/79r and have tuned in the channels via the interaction menu using 3 1 9 7 5 3 mute on remote and the sound wont work now. is there something i have to enter to...
open the cover of your tv look for the sound IF using a plastic precesion screw driver adjust the IF counter clock wise slowly untill you reach a good sound or clockwise...if nothong happen solder a 0.2 ceramic capacitor to your sound IF at the coil of the IF under the board the IF has two terminals for the coil.sound if is located near the tuner section..there are two IF the video I.F and sound I.F
May 20, 2010 | Televison & Video
Belkin f5d8635-4 Router connection problems
Open the working pc open internet explorer and type 192.168.1.2 in the webaddress bar. this will open your belkin router settings page. On the left choose channel and ssid. If it asks for a password leave the password box empty and just click submit. The channel is the frequency your wireless network operates on. Some channels are more stable than others, but its just trial and error until you find the most stable for your area. Change your wireless channel to a different one (any channel is fine, personally 1,11 or 8 works best for me) and click apply changes. Hope this helps.
http://www.thinkbroadband.com/hardware/reviews/35-belkin-f5d7630-4a.
Apr 15, 2010 | Computers & Internet
How do you tune in a alba tv with no remote control
There is no way to tune it, the menus that you need to bring up can only be accessed with the menu buttons on the remote
Feb 28, 2010 | Televison & Video
Samsung 50'' plasma model ps50b450b1wxxu keeps losing all stored channels and needing re-tuned,tv says weak or no signal, it is only 3 weeks old, is it something i,m doing wrong or is the tv faulty?
If you are always needing to auto program the tuner then I suspect a faulty main board. Bring it back as it should be under a 30 day return policy..
Nov 03, 2009 | Televison & Video
Tuning problem
Oct 06, 2008 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Televison & Video Logo
173 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
