Question about Carrier Heating & Cooling
Carrier FE fan installed as counterflow with 10 kw heat strip.....heat strip heating wire shorting to support bracket....
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
SOUND TO ME LIKE CRACKED CERAMICS INSULATOR, OR THE SUPPORT BRACKET IS NOT IN IT CRADDLE.
Posted on Sep 03, 2008
Replace a kfceh3101c15 with a 20 kw. 15 kw just is not keeping up in this weather
The best answer would come from Carrier. Here is their contact info-
Feb 23, 2015 | Carrier Heating & Cooling
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
Wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
If you are using strip heat as seperate mode you must install a fan isolation relay which would be energized by emergency ht mode of stat.
Nov 25, 2012 | Carrier 38CKC042 Air Conditioner
New heat pump system freezing, questioning wiring.
W1 and E on stat need tied together. When W1 comes on wire where all heat elements come on. On the outside unit defrost board set the 45-60-90 to 45 and see if that takes care of the frost problem.
Jan 03, 2010 | Heating & Cooling
Goodman unit blows 45 amp fuses only in heat mode, worked fine all summer on a/c. It works well for some time then blows them again.
Check the breakers on the unit How many KW--electric heat? Check to see if you have the right wires wired up to the correct breaker cause some units have 40---and ---60 ---amps breakers and your thickest wire could be wired to the 40-amp breakers,, (some 5 KW pullls 19-23 amps respectably some breakers have 7.5 KW heat stips and pulls more and if the wire size can,t cary the amps, then all you have to do is reduce a heat strip.
Dec 18, 2009 | Goodman GMS90703BXA Heater
Nordyne GB5BM T49K C what heat strips do I need or what KW ?
You need to know how much heat you need (heat loss) and then figure the KW of heat that you need to make that. (3415 BTU's per KW)
Nov 10, 2009 | Heating & Cooling
10 kw heat with 2 speed fan
Checkout GOODMAN ELECTRIC FURNACES . website.
Sep 02, 2008 | Goodman CKL36AR36 Air Conditioner
Replace Carrier tstatccshp01 builders standard thermostat with Honeywell rth7500 series and wiring not matching Does O wire go to Aux..? fan working but no cool air.
No... Aux. is auxiliary heat strip. This is usually a white or black wire its up to the choice of the installers preferance. O or orange wire. is used to the reversing valve on a heat pump. If you do have a heat pump there is a programing section inside the Honeywell t-stat. which should say heat pump or straight cool, then another section that will ask if you want the reversing valve to energize in heat or cool. most Heat Pump brands energize in cool the exception is Rheem and Ruud they energize in heat.
May 17, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
158 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
