Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Automatic shut off craftsman 1.5 hp compressor
When the pressure increases towars the red zone the auo shutoff never kicks in. The pressure builds until i turn it off. It has never been used. Is there anything i can do?
I bet you that it is the pressure switch is defective or out of adjustment.
Posted on Oct 12, 2008
  • 828 Answers
It sounds like the pressure switch is defective or the unit is miss-wired . If you have the owners manual check for a wiring diagram and follow the chart to try and locate the problem. If it is new return it to the place of purchase and have them fix or replace it.
Posted on Sep 09, 2008
Craftsman 1 1/2 hp air compressor model 106.152680 builds air but when it shut off it feels like air leaking out of pressure switch someplace.
It will leak until head pressure is drained. I'd it keeps bleeding until late no more air in than your tank check is bad
Apr 02, 2017 | Craftsman Air Tools & Compressors
Pressure won't re-build after cut-in
So you are saying that it starts and builds pressure and then shuts off, then when it comes back on again, there is no pressure? Sounds like the unloader valve is sticking open.
Aug 08, 2013 | Craftsman 3 gal. Air Compressor, 1 hp,...
I have a 3 gal 1 hp air compressor and it will only build pressure to 27 lbs.
If it makes hesitation sounds just before shutting off, you need to oil the compressor as per the manual. This is the most common problem.
If it is kicking on and off normally, you need to adjust the pressure relay. The instructions are under the cover.
May 14, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
What is the ut out pressure, the motor keeps running past the red zone of the guage, when would it stop automatically?
The cut out pressure is adjustable. Normally, it is not above 120 PSI. It is adjustable with a screw on the cutout switch.
Oct 03, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman air compressor spitting sparks behind fan
If it is an oil type make sure it has oil. If it is the dry type you need a new compressor.
Jul 29, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
374 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
