Why do I get the following "Fatal Application Error" error when using my MobilePro: "Application filesys.exe has performed an illegal operation and will be shut down. If the problem persists contact the program vendor." Clicking on the Ok causes the system to perform a "hard reset".
This problem may occur if the user allows the batteries to discharge to a state where the MobilePro must shut itself down. This state may cause the system storage memory to become unstable requiring a "hard" reset after the system has been fully charged again. Failure to perform the hard reset may result in data loss at a later time. The user manual states that if you receive a message indicating that the batteries are low, immediately connect the AC adapter to the device. The solution is to perform a "hard" reset after fully charging the internal batteries, and then install the service packs, software updates and user software.
