I purchased a Phillips monitor model no 190s when i turn on my computer a box comes up with attention for best results 1280x1024 @ 60, problem is I have already set the display. why is it coming up, how do i correct this?
  • whitevixen Jan 16, 2009
    Thank you so much, I asked so many people and did not find a solution until you came along!! :-)
You can get rid of this message by entering the monitor setup by pressing the MENU button. Then use the DOWN arrow button to go to 'setup'. MENU, then DOWN again to 'Resolution Notification'. MENU, then DOWN to choose the 'off' setting. Voila!
Cameron
Posted on Jan 15, 2009
How do I tilt my Samsung 190s monitor?
If you mean tilt back/forward, grab the screen with your hands from both sides and tilt the top towards you are away from you.
If you mean rotate to get vertical instead of horizontal orientation, you should look at the back of your monitor to see if it even allows that movement.
Try downloading the User Manual if you don't have one:
http%3A%2F%2Fmypdfmanuals.com%2Fuser-manual%2CSAMSUNG%2CSYNCMASTER%2B190S%2C771044.pdf&ei=fwdgUvSCBoPiyAG_u4HgCg&usg=AFQjCNFYTlCuYjoHd4j7epiG7VRCpSalsw&sig2=iplcvOt8JdNoQqHqbG1g5A
Oct 17, 2013 | Samsung 190S (Silver) 19 in. Flat Panel...
No display on 190S monitor. It's 3 or 4 years old and has worked great until today. The green power light is on, but no display. I tried rebooting the PC and turning the monitor off and back on. The...
It can be the backlight inverter circuits went out, open it up and look for bad caps with bulging tops first, then look for 12~18vdc feeding the inverter circuits. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | Samsung 190S (Silver) 19 in. Flat Panel...
My Philips 170C monitor does not work when I turn on. It only says "attention signal off".
it thinks this is no input signal. make sure your computer is on and the cables are secure, switch your screen with a known good one from a freind. this will rule out your computer. if the pc is fgood maybe go into the bad monitor menu settings and make sure the input mode is correct. if this is not the cause you may need to have it repair, your monitor video or display board maybe bad.
Dec 26, 2009 | Philips 170C4FS 17" LCD Monitor
I have a monitor philips 190S and the osd main control is locked. how i can unlock?
23 Oct 2008 ... There are a few things you can do to solve the problem, ... The menu should be reset and the flashing OSD control message should disappear. ... controls locked, then it comes up again saying OSD main controls unlocked. ... I have a Philips 190S monitor. I do have a button to enter the onscreen menu. ...
filetonic.com/blog/2008/10/23/osd-main-controls-blocked/
Dec 06, 2009 | Philips 190S7FB 19 inch LCD Monitor
Philips 190s turns itself on/off
Mine is a 190s Monitor and not a TV with any kind of remote unit controlling it. I had this issue about a year ago and it sorted it's self after a week or so left turned off. This makes me wonder if it has to do with heat and humidity affecting the micro switches located behind the push button controls on the removable screen surround.
Dec 01, 2009 | Philips 190S8FS 19 inch LCD Monitor
Theft Mode Enabled on Philips 190s9fb/27 monitor
The display may have been tasted on another pc from the store/company.. This message is activated after a while (or immediately) when connected to a new box. So far I have had this issue on a Philips 22" wide and HP.. both fixed after installing the little software that came with the displays. HP usually has a THEFT option within that installer. The philips one fixed itself upon restart.
Mar 16, 2009 | Philips 190S9FB Monitor
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
Help with my 190S monitor
I have Philips 19C monitor. From today, every 5 secs an attention message
"osd main controls locked and unlocked"
The AUTO(OK) bottons for 10 sec not give nothink
What i can to do with this?
Gregory
my mail - communar@agry.gov.il
Thanks
Aug 22, 2008 | Computers & Internet
The OSD button has gone faulty.
The button will need to be replaced , or it might just need spraying with a contact cleaner like RP-7 or WD40.
Both solutions will require the removal of the front cover to access the button.
Jun 06, 2008 | Philips 190B6CB/27 19" LCD
Blue Resolution Box
To turn off the reminder, use the buttons on the front of the monitor to do the following:- Press #1. Use down arrow to highlight Setup Menu and press #2. Use down arrow to highlight Resolution Notice and press #2. Select Disable and Exit.
Aug 13, 2007 | ViewSonic VX2235wm LCD Monitor
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
