Question about Dell Axim X5 Pocket PC
Axim wallaper resolution....
What should I set the resolution to for the wallaper?
    Master:
  • 852 Answers
The screen is 320 x 240 You have the lower border and upper board which say maybe 10 pixels each. Take the 320-(10x2) borders and you will have 'about' 300 x 200 for a 'full' picture/backdrop.
Posted on Sep 14, 2005
How do you install downloaded programs on the Dell Axim X30?
Downloaded programs can be installed onto the Dell Axim X30 using Microsoft ActiveSync. Microsoft ActiveSync can be installed onto your computer using the Dell Companion CD which came with your Axim X30.
Once Microsoft ActiveSync is set up on your computer, if the program you downloaded came in an installer file, then double-clicking on the file will start the installation wizard and the software will be automatically transferred to the Axim.
If the program you downloaded did not come as an installer file, then double-clicking it will bring up an error message. In that case, use ActiveSync Explore to copy the program file to the Program Files folder on your Axim.
Mar 05, 2011 | Dell Axim X30 Pocket PC
Axim connected to internet, cannot browse as error states page not connected why
I some how stumbled on to the resolution. I had to hard reset the device and was able to reconnect easily. I was never able to find the solution to repair the connnection problem. I tried to change every setting within the connections to no avail. Make sure you have your wireless router on and when you enable the WLAN utility it will ask if you want to connect to the internet or work -- select internet and you are off and running
Feb 28, 2011 | Dell Axim X50v Pocket PC
How do I sync axim to outlook?
Try deleting the active sync partnership as mentioned in this post -
http://www.aximusers.com/forum/axim-x51-x51v/6651-synchronize-outlook-contact-problem.html
Jul 17, 2009 | Dell Axim X51v Pocket PC
Set password on my dell axim X51v pocket pc and forgot it
Once you forget the Password, your only option is to perform a Hard Reset on the device and reset back to Factory defaults. You data will be lost, as this is in place to protect you in case the device has been lost or stolen. If you have backups, or sync the device with Outlook, you can run a restore or re-sync the device to populate the data back into your device.
Hard Reset -
NOTICE: When you do a hard reset, you lose all the data stored in your device
Flash memory, and any programs that you installed on your device.
Do a hard reset if:
  • You want to restore the device to factory default settings.
  • You forget your password and need to reset it.
  • Your device is experiencing severe operational problems and you have already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you do a hard reset.
To do a hard reset:
  1. Press the Power button to turn the Axim unit On.
  2. Press and hold the Power button down while using the Axim stylus to press the Reset button at the same time.
  3. Release the Power button and the Reset button. The To clear all data in the memory screen appears.
  4. Press the Contacts button on the Axim to delete all of the data in the memory of the Axim handheld.
  5. Press the Mail button on the Axim to cancel the operation without losing data.
Mar 16, 2009 | Dell Axim X51v Pocket PC
Not working with Dell Axim x50
No, the la-4137 is not compatible with the Axim x50 or x50v.
Dec 14, 2008 | Symbol Spectrum24 Wireless Neworker...
Dell Axim x51 will not connect to system
windows vista uses its own sync software, which is available on the windows marketplace
if your vista is original you can upgrade to this software
if you use xp version, just keep using the usual active sync
Oct 04, 2007 | Dell Axim X51v Pocket PC
Dell axim x3i problem
Press and hold the reset on the back and press and hold the power button. This will reset to manufacturing settings.
Sep 21, 2007 | Dell Axim X3i (400 MHz) Pocket PC
Touch screen freezing up
Look at this http://www.fixya.com/support/t132057-getting_past_align_screen
you basically need to get the wire to stop touching the home key, which can be accomplished (as described in the link) with either the quick fix method, wedging something in the bottom screen, or the better-long term method of opening the axim up and taping the part that has shorted.
best,
Greg
Sep 04, 2007 | Dell Axim X5 Pocket PC
AXIM Disconnecting
Go to Start Settings System Power Control Uncheck (On external power) or set it to what ever mins you want
Sep 14, 2005 | Dell Axim X5 Pocket PC
Axim wont automatically shut off
I would guess your light should dim after 5 minutes. But I bet your axim wont shut off for 2,3, or 4 hours. My battery is wonderful so I have it shutting off after 2 hours.
Dell Axim X5 Pocket PC Logo
Clive
Clive
Alun Cox
