OKI B4400 PRINTER OFFLINE AND WARNING LIGHT FLASHING - WILL NOT COME BACK ONLINE. WE THINK THE DRUM MAY NEED RESETTING BUT PRINTER STATUS SAYS INITIALIZING WHEN WE GO INTO THE STATUS MONITOR AND WE THEREFORE CAN'T GO INTO MAINTENANCE TO RESET THE DRUM. ANY IDEAS?
  • Anonymous Jan 19, 2009
    I have the same problem.
    Oki ask me to register this problem.
  • dennly28 Feb 01, 2009
    C3200 status monitor says "printer connection error" but it prints a test page and full printer pages from the PC OK. Re-installing the software makes no difference. Looks like the printer is not talking to the driver software.
    All cables renewed and checked, so it's something in the control software, driver software or printer firmware.
jaylex
  • 417 Answers
SOURCE: Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Posted on Feb 04, 2008
SOURCE: how to switch from "offline" status to "online" status
I had the same problem with a Brother MFC-6490CW AIO printer. Here is how I resolved it:
Open the printers folder.
Right-click on the Brother printer and display the Properties page
Select the Ports tab.
In my system (Vista Premium), the selected port was a WSD port (whatever that means). Further down the list, there was a TCP/IP port that was obviously created by the Brother installation software. I selected the Brother-created TCP/IP port (which deselected the WSD port), applied the changes, and suddenly my printer was online. No idea what the difference between these two ports is, but I'll stick with the TCP/IP port until further notice.
Posted on Mar 02, 2009
SOURCE: printer status offline needs to be online
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
Posted on Apr 04, 2009
  • 628 Answers
SOURCE: OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Posted on Apr 20, 2009
trikha_karan
  • 66 Answers
SOURCE: My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Posted on Nov 10, 2009
Printer still say need new drum even after being replaced
You need to reset the drum count. take the printer offline by pressing the online button. next scroll down on the menu button til you get to Maint. Menu. Next press Item+ button 2 times. LCD should say Drum count reset. next press select button.this will save the option. next press online button
to put the printer back online. you should be ok to print
Good Luck
Feb 23, 2011 | OKI B4350 Laser Printer
There is a yellow light flashing which i think is stopping my printer from working.it is the symbol furtherst to the right out of the 4 symbols any ideas
The rightmost LED is the Error light. How fast is it flashing?
If the light is flashing 1 long flash every 4 seconds (no other lights flashing), then either the image drum needs to be changed or the toner is low.
If the flash is one blink a second, then you have a paper problem or a cover open.
If you installed the OKI software with the driver, you can use the Printer Status monitor to identify the problem and order the consumables if you have a slow blink error. (Open the printer control panel (Start >Programs > Status monitor) and Maximize the window to see the Printer status.
You can find the manual for the OKI B4100 here: http://my.okidata.com/PP-B4100.nsf?opendatabase . View all manuals on the right. If that link doesn't work, see the support site: http://my.okidata.com/Home.nsf/Welcome?OpenFrameSet and select the B4100 in the Color/Mono Page Printer drop down menu.
I hope this helps.
Feb 14, 2011 | OKI B4100 Laser Printer
OKI B4400 toner - is the chip reusable? I get toner not installed
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
Jan 27, 2010 | OKI B4400 Digital Mono Printer - Black
I need to know OKIB4400 LASER PRINTER; TRIANGLE W/ EXCLAMMATION
This is an "Attention" indicator. Has a lot of meanings when blinking and all of them described in the user's guide. There is also Status Monitor Software that can be installed after the printer driver and which displays printer status on the PC's screen. Much more convenient way to get information from the printer than deciphering indication of the lamp in question.
Jun 05, 2009 | OKI B4400 Laser Printer
Dell Printer 1720dn - Unable to reset drum counter..
"Press & hold the cancel button untill all lights start flashing in a sequence and then i release the button and close the front cover." "DO NOT release the button, but continue to hold down it while you close the front cover.
Printer offline: Right click on your printer in the "Printers and Faxes" folder and "UN Check" use printer off line,
May 11, 2009 | Dell 1720dn Laser Printer
Poor copies with OKI B4400
Possibly a fuser issue. Check by sending a 1 pg document to printer and opening cover when paper picked from tray but before it enters fuser. if image good then problem caused by fuser and you will need to replace. If image bad then possible defect with drum.
Oct 04, 2008 | OKI B4400 Laser Printer
949 people viewed this question
jasbo
jasbo
