Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover steam cleaner cleans but no longer suctions up the mess
Cleans but does not suction widespread model 6500
  • 3 more comments
  • Anonymous Sep 03, 2008
    puts the water down but does not suction it up
  • fastcatz007 Sep 10, 2008
        Was steaming the carpet as usual.  The clean water from the top compartment came out fine, but the water on the carpet is not being sucked up.
  • ermocidae Oct 04, 2008
    the water will not **** back up after it its put on the carpet
  • Anonymous Nov 04, 2008
    Same problem here...steam vac will clean but will not "vacuum" up the water.
  • DaizofRaine Nov 16, 2008
    the vac spins, dispences water, but will not **** up. Help!..we have a carpet full of water now,,
I had this problem and it was solved by closing the door where the hose attaches. If this is not latched or if any other hose connection is loose the suction will not work. Good luck!
Posted on Nov 05, 2008
Fart I give up
Posted on Oct 18, 2008
It cleans but dont **** the water back up
Posted on Oct 04, 2008
My Hoover is not sucking up the water? Why?
Posted on Sep 24, 2008
How to clean suction area
If you are referring to the front nozzle area, Hoover has made a tool called a nozzle cleanout tool # 39514003
Sep 13, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How do I clean the hoover steam vac floor cleaner machine
Nozzle Clean Out tool is NO LONGER AVAILABLE from Hoover. Hoover stopped making this part over 1 year ago, and it's not sold any more. What you'll need to do is remove the dirty solution thank, unscrew the one silver screw on the suction port of the clear window, then turn the machine upside down and remove the two silver screws on the bottom corners of the see thru window. This will then allow you to completely remove the see thru part to clean inside of it. Unfortunately with this model that's really the easiest way to do it now that the tool is no longer available.
Apr 18, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hello,We have an Hoover Mach 5 Cyclonic vacuum that has no suction. We have cleaned and checked all hoses, belts & filters. Please help us.
With this model, remove the dust tank, and turn it on, check for suction at the lower intake. If you have suction, install the tank and remove hose, and check for suction there. keep following until youn lose it. Then you problem will be between those 2 areas
Mar 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Vacuums
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Upholstery conversion
Take out the duct in front of the tank (#3), the hose end will have a duct on it that you insert in its place. This provides the suction for the hose. Don't forget to put that duct you took out back in place, or you won't have suction when you use the steam cleaner.
Nov 21, 2007 | Hoover F5888-900 SteamVac Upright Wet/Dry...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
297 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
