Question about Motorola Mobility RAZR2 V8 Cellular Phone
Motorola V8 Hello there ! On my Motorola V8 in the top left hand corner, right next to the Signal Strength, I have an Icon that looks like a scrol of paper that is open. What is this, and could this be the reason my battery charge goes down rapidly? e-mail address is helen.griffiths@jacobs.com
  • chelle007 Jan 12, 2009
    I have the same problem and don't know what settings to adjust - can someone talk me through the menu options and the changes required.
  • ronzkie Feb 06, 2009
    my motorola v8 is needed to repeared its totally shutdown i cant used it already.somebody give me an address and shop to fixed my motov8..tnx
    Problem Solver:
  • 13 Answers
Mlralston, taht symbol means that your phone is on the vibrate profile.
Posted on Apr 23, 2009
Hi
I purchse a V8 luxuary edition unlocked, hen I want to make call I see that signal is ok, but when I want to call, it said call failed and down also the signal to 0...so the signal return and when I want to make call, it down...PLZ help.
Posted on Nov 24, 2008
  • itreecom Nov 24, 2008
    Hi
  • 3 Answers
Its the data connection you should ether check if you have the picture mail option on auto retrive if it is on auto switch to manual and if problem still goes on just turn off the phone and remove the battery
Posted on Oct 14, 2008
  • robielugo Oct 14, 2008
    and yes the data connection does kill your battery
I have an icon next to the battery icon it is a phone with a jagged line next to it any ideas what this is
Posted on Oct 09, 2008
How do I change the language on me Nextbook 9 from Spanish to English
If you click (on the main screen) in the top right corner on the (6) little squares. Then slide through the pages on the first tab. Do this until you see a picture icon of a grey square, outlines in blue with blue lines and dots on it. The first line will be slightly farther to the right than the second and the bottom (third) bar will be almost completely across the box. Select that. Then on the left hand side look slightly farther down the mid ways. you will see a choice that has a picture icon that looks like a sticky note with "A" on it and beside it will say "Idioma y entrada". Select that. at the top on the right select "Idioma" Then scrol and select "English(United States)". Unless you are in the UK, Select "English" UK
Jan 07, 2017 | Cell Phones
How to pair bluetooth device
First, make sure Bluetooth is enabled on your Lenovo. Right-click on the wireless connection icon in the Windows system tray. The icon is usually a wedge-shaped icon showing signal strength bars. The icon is usually located at the bottom right corner of the taskbar at the bottom of your screen. So, right click on that icon and select Open Network and Sharing Center. In the new window locate and click on Change adapter settings on the left-hand menu. In the new box that opens search among the tabs for information to confirm Bluetooth is "enabled".
Next, according to Sony's help guide try the following:
Unable to connect the speaker to a BLUETOOTH device with One-touch connection (NFC)
Keep the smartphone close to the speaker until the smartphone reacts. If you fail to connect, move the smartphone
slowly on the N-Mark of the speaker.
Check that the NFC function of the smartphone is set to on.
If the smartphone is in a case, remove it.
NFC reception sensitivity varies, depending on the device. If you repeatedly fail to connect the speaker with a
smartphone by one touch, connect it to the speaker by on-screen operation.
Check that your smartphone is compatible with NFC. Look up information on the issue on the customer support
website.
Sep 27, 2014 | Lenovo Computers & Internet
My Magellan Roadmate 3045 is not getting any signal. I turn it on, and it doesn't even attempt to acquire a signal. The satellite icon in the top right-hand corner of the menu which indicates signal...
Mine actually stopped working the same day you posted this. How strange is that? I have not been able to figure out what is wrong with it. Have you figured out a solution?
Aug 06, 2011 | Magellan Roadmate 3045 - uses Gomadic...
Chang my gmail language from spanish to english
Click on the right corner where your name appears. Once that box opens click the second blue link down from your name. this takes you into account settings.
Look for the Gmail Icon and next to it is a link. this is settings for your gmail click it.
The first setting box right off the bat is Language in spanish it should say Idioma, change it to english and scroll down and click save changes next to cancel
May 04, 2011 | 2006 Eagle Premier
Can you please tell me how to work out if my iphone is 2g or 3g
Its quite simple, Just see near the signal strength icon on the top left hand corner..you might see a 3g or 2g written der...
May 27, 2010 | Apple iPhone Smartphone
Motorola e815 Verizon Phone Won't Make Calls
restore your phone settings and try it
Jul 17, 2009 | Motorola Mobility E815
Message not able to be opened or read.
Do you have proper signal strength? If so, i would be willing to bet that the phone doesnt have enough memory left to download the message. If you have good signal and it wont work then try deleting a few of the pictures or vids that you allready have on your phone then turn the phone off then back on to try downloading it again... Hope this helps
May 19, 2008 | Motorola Mobility RAZR V3
Pairing headset
If you have a motorola the pass key is 0000 unless you changed the pass key because then nobody will know it except you. Hope this helped =)
Jan 31, 2008 | Motorola Mobility H350 Wireless Headset
Indicator unknown
the is the bluetooth icon.
Kinda looks like two side ways triangles stacked on top of eachother. GO into your settings and turn it off if you dont wantto use it. Bluetooth will drain a battery.
Jan 18, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR2 V8 Cellular Phone Logo
567 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
