Question about LG Televison & Video
MY LG 32inch 5010 TV has a slight humming noise when it is on, is this natural
  • 2,920 Answers
No it means you have a problem somewhere inside the tv
Posted on Sep 03, 2008
I just got a hisense 32inch smart tv and Its Making a humming noise from the speakers. How do I get rid of it?
Have you tried going into the menu and resetting to factory default.? If so how old is the TV?
Nov 08, 2014 | Televison & Video
Lg tv humming noise when tv is on
The humming noise is most likely coming from the power supply.
If the unit is worth the repair cost ( Over $100.00 ) you should have it repaired.
If not, deal with the noise until it goes out.
May 12, 2014 | Televison & Video
Humming or squealing noise when tv is turned on (model 32LG30)
Be sure you have installed the stand scresw weather or not you are using the stand.
The back panel can vibrate without the screws.
Other sources of a hum are the coils on the power supply.
The power supply would have to be replaced to solve the issue.
Jan 19, 2010 | LG 32LG30 32 in. LCD HDTV
Is it possible to connect an LG 5010 tv to a
Yes, you can connect any home system into the TV by either using a scart or HDMI connector to produce the picture on the TV. The sound will still be present through the cinema system
Nov 22, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a humming noise coming from my new 50in panasonic plasma tv. Is this a common problem and if so what could I do about it? Thank you for your time. Pat
The humming noise should be verry low . It is caused by the powersupply and switching fets on the boards. A plasma screen always produce some sort of humming noise when listen carefully to the device but it shouln't be anoying when enyoing a movie. So it is a natural thing but again it should not be noticable, enyoing a movie at apr. 3 meters or so...
Jul 09, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
TV made humming noise for past few months and after it warmed up the humming would go away. It that same thing today and a pop noise came and the screen will not come on, and the tv shuts off and then...
i took off the back and pulled out the the fan. Then put in a fat screw between a slight gap whick kept the fan from hitting what ever is causing the noise. probably not safe but nothing bad happened yet.
Apr 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
My lcd tv makes a humming noise
Try removing all cables going to the TV except the power cord. Power on the TV and press mute. If you have any unwanted noise, then you have a defective TV and since it is new, you should get an exchange. If there is no noise with the A/V cables removed, then you might have hooked the source (cable box/DVD Player) into the wrong inputs of the TV.
Mar 14, 2009 | LG 42LG30 42 in. LCD HDTV
Trobleshoot RCA F32650 32inch tv
I think that something has gone wrong on the power supply board. If you can check this for yourself otherwise find a competant technician. Hope this helps.
May 11, 2008 | RCA F32650 32" TV
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Humming noise
Most times a humming noise in a Plasma tv is associated with high altitude. If you live over 3500 ft. and when you first turn on the unit is has a slight buzz and it gets worse as it warms up then you have what is referred to as high altitude sickness. You shoul contact the manufacture with this problem and the should exchange the unit with one tested for proper operation at high altitude. If you do not live at high altitude then there is a problem in the unit that should be diagnosed.
Dec 18, 2007 | LG 50PX5D 50 in. Plasma HDTV
Televison & Video Logo
137 people viewed this question
Computer Repairing
Computer Repairing
