Question about RIM BlackBerry 7290
Key pad and scroll button stopped working
I purchased the blackberry 7290.
Now the buttons on the key board is not working as well as the scroll button has stopped too.
I cant take any call as unable to press any button.
Calls are coming .
I switched it off and on several times but still the same problem , please help.
Thanks
Faisal
ARM problem, take it to a service center to fix it.
Mic
Posted on Sep 07, 2008
Why won't the number 1,0 and space bar button work?
Have you tried a battery pull...... restart by removing the battery while your device is Powered On , try it and see if you're able to access your keyboard . you can try factory default to reset phone ...When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
All phone data will be deleted. Data on your SIM isn't deleted.
1. Find "Security Wipe"
  • Press the Menu key twice.
  • Scroll to Options and press the Navigation key.
  • Scroll to Security and press the Navigation key.
  • Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Cardand press the Navigation key.
  • When the box next to the menu item is ticked (V), the selected data will be deleted.
  • Highlight the field at the bottom of the display and key in blackberry
  • Scroll to Wipe and press the Navigation key to restore the factory default settings.
  • Follow the instructions on the display to set up your phone and prepare it for use.
May 13, 2014 | RIM Blackberry Curve 9320 Smartphone -...
Key buttons are not working after booting the device
the buttons or contacts of the key pad are probably worn on so you will probably have to replace the phone.
Jan 24, 2011 | RIM BLACKBERRY CURVE 8520 QWERTY KEYBOARD...
Compaq win7 touch pad scroll is not working
check to see that you have not locked the scroll pad. either button next to pad or a func+key will activate it. in some cases you have a a spyware virus stopping it.
Dec 06, 2010 | Compaq (153515-001) Touch Pad
There is no option to turn off call barring and to turn my radio on. I bought a used unlocked 7290 for an upcoming trip to Spain. I can text ok. What do I do?
Hello. Begin by removing the battery from the black berry for 5 minutes. This will reset your black berry to factory settings and may well solve your problem. If it does not, you will have to take your blackberry into a phone store. Joe
Mar 07, 2010 | RIM BlackBerry 7290
How do i do a quick name search with from the numeric pad on the black berry storm.
Press the call button and change the option to show contact list as initial view.
Then change the right side convenience key to show the virtual key board, screen/key options then change
The right side convenience key to show virtual key board, so when you press call button, it shows contact, then you press side convenience key and a few letters of the person you want to call
Jan 21, 2010 | RIM BlackBerry Storm 9530 Smartphone
Blackberry 7290
should be a button in bottom right of phone. Here is a picture. Hold button in for a couple seconds if pushing it doesn't turn it on. ed90572.jpg
Dec 20, 2008 | RIM BlackBerry 7290
Blackberry 7290 unlock proceedures
Hello.
I think I see your problem.
The 'mepd' must be uppercase. Hold the shift key down while typing in the MEPD.
Once you get into the area that shows what limitations are active or disabled, then you must use the Alt. Option key on the fare left third row of keys down. Holding the Alt. Options key, type MEP then release the Alt. Option key and press 2.
You should now be prompted to enter the unlock code. If not, start from where you had the last correct results. Also, If it will not work, back all the way out to the memo icon and try the keys you need to type to insure all of the keys are working and you are not fighting a temperamental key switch.
Good luck in your quest.
If you still need more help, just ask.
Oct 17, 2008 | RIM BlackBerry 7290
My BB pearl is haunted...
i had a similar problem before and it turned out on of the side buttons had jammed so it was doing all sorts of mad stuff. to fix this is just pulled the side panel off cleaned out any dirt/dust and made sure the button was pushing in and coming back out without obstruction. this sorted out my "possessed" blackbeery issue. hope it helps
May 06, 2008 | RIM BlackBerry Pearl 8100
Unlock BlackBerry 7290
Unfortunately, the unlock code for a BB 7290 is unique to each phone. The unlock code is based on the IMEI of your BB. After getting an unlock code then the steps to unlock are:
1. go to options
2 scroll to SIM CARD then press jog dial in once to select it
3. Type MEPD (not case sensitive) ( you will not see text appear on screen while typing )
4. Does it say Network active? if so your phone is locked
5. Press and hold the alt key (half moon looking key on the lower left side)
6. as you are holding the alt key type in MEPE (not case sensitive) ( you will not see text appear on screen while typing )
7. type in the unlock code when prompted
8. After entering the code press the jog dial in
9. Your phone is now unlocked!
Feb 27, 2008 | RIM BlackBerry 7290
RIM BlackBerry  7290 Logo
322 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
