Question about NAD C521 CD Player
NAD C521 discs not spinning
My player was frequently failing to recognise CDs when i loaded them, even failing to recognise when there was no CD in the drawer. After removing the cover I realised this was because the motor doesn't start spinning when the drawer shuts. If I give the machine a physical shock (e.g picking one side up by an inch or so and dropping it) the motor starts. Obviously this is not a long-term solution! There doesn't appear to be any loose connections or any significant dust in the machine. Any suggestions will be gratefully received.
    Sniper:
  • 99 Answers
If the motor needs a manual nudge to get the disc spinning then you have a faulty spindle motor.
i've had various cd players with exactly the same problem and once i replaced the spindle motors, they all worked faultlessly.
hope this helps.
Posted on Jul 02, 2010
    Genius:
  • 1,175 Answers
HI...
I own a few NAD CD players and have repaired several for customers.
Main trouble? ..The belt the works the drawer. It also runs the laser assby lift to meet the CD to read. No lift-No spin.
These units also use 14 volt wire-lead bulbs to backlight the display.
This is also a common failure.
Posted on Apr 07, 2009
Hi, i have the same player and had the same fault,when moved "vigorously" i could hear something moving inside. Opening the unit i found a small black plastic peg loose inside. Examining the disc transport i found a microswitch with nothing to do! Further examination brought me to a hole in which to put the aforementioned peg,thus solving my problem!!!
Hope this helps someone
Posted on Mar 17, 2008
    Novelist:
    Champion:
  • 277 Answers
The CD player has a sensor that is supposed to detect when a disc is inserted and spin it up etc. yours might be the problem, either it has some loose connections (that you haven't noticed) or it simply misbehaves. Another thing could be the motor itself that somehow 'misses' the spin up signal and needs a 'manual' boost. The best solution in your case is probably to bring it to some lab.
Posted on Sep 15, 2005
NAD C521 on / off button light
"POWER ON: Press this Green button to switch on the power to the disc player from Standby mode. The LED will change from Amber to Green, and the EFL display will illuminate."
So besides the L.E.D. the unit has another visual indicator that it's turned ON, the display lights up. Is this worth pursuing a fix?
Mar 03, 2010 | NAD C521 CD Player
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
NAD C521 CD Player It will not play my CDs. The CD drawer closes normally with CD in place but after a pause, the drawer opens again. There is no 'no disk' warning. The 'no disk' warning does appear...
The tray belt raises the laser to proper focal length at the end of closing the drawer. This demands more grip from the belt. If the belt is sloppy, it will slip at this point, even though the drawer is shut. Took two years of repeatedly cleaning lasers to notice this.
Sep 07, 2009 | NAD C521 CD Player
My NAD C251i CD player isn't reading disks - platform stops short
To fix it, you need to replace the spindle motor top bearing. The bearing is worn and the player mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. Because the disc is spinning fast.
Replacing the bearing should resolves the problem.
Hope this helps and have a great day!
Sep 01, 2009 | NAD C521 CD Player
NAD CD 5425 - No Spin - Sometimes
I've dealt with this type issue quite a bit.
Believe it or not the drawer belt needs to be changed.
If the drawer isnt drawn all the way into the unit...the disc motor wont spin and ....you get rejected
Dec 23, 2008 | NAD C521 CD Player
NAD C521i four year old. Usually fails to find cd's When it does tracking and sound is bad.
Also the lens on the laser could be dirty.
Take it to a tech . Try a local stereo store . They should know who's best.
Happy new Years,
Scott
Dec 11, 2008 | NAD C521 CD Player
NAD 502 CD player problem
Does it have a failing drawer belt? My 522 was fixed after that.
Jun 18, 2008 | NAD C521 CD Player
No disc
Also, if it reads poorly, the lens on the laser could be dirty.
Take it to a tech . Try a local stereo store . They should know who's best. It's a quick easy job for a tech who knows what he's doing.
Happy new Years,
Scott
Jun 06, 2008 | NAD C521 CD Player
Laser unit NAD 5100 Monitor Series
Hey, I think you can bye new laser here http://www.pltv.org.uk/laser.htm I have a nad 5300 monitor series, same laser as 5100, you can buy the hole cd player from http://www.miguelovitch.dk Laser work, but problems with cd transport. When i 'help' the cd transport, cd play as expected. And i agree, it is a nice cd player, also i have heard lot of nad cds on quad 405, sounds realy good. Try to visit my site, i also have a lot of free schematic for nad, denon, quad and mora. Also repair notes for amplifiers, tech videos, diy schematics and more.. Also at this moment i am working on a new 'nad cd service movie) including cleaning, maintenance, repair and more on nad 522, 501, 502 c521 and more see you best regards michael miguelovitch http://www.miguelovitch.dk
Aug 14, 2007 | NAD C521 CD Player
NAD C521 CD Player Logo
853 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
