Question about Hotpoint Washing Machines
Hotpoint aquarius washing machine wf nstopped in middle of programme error message won't restart
  • 3 more comments
  • Patrick Bryant Sep 03, 2008
    Have tried this answer, machine still locked shows a scambled code EE5E no top legs on end two E's
    What happens is you select your programme, switch on and a garbled error message appears, but the proramme runs it cycle including releasing the door but no water comes in the machine. I have checked water supply to the machine O K.Is it the water valves are getting no imformation from main circuit board therefore no letting any water into the machine
    Thanks for all your help.
    Problem was the pump was all bunged up, clean it reset machine works fine
    Pat Bryant
    Thanks all.
    Pump bunged up cleaned it, reset the machine works pefectly
    Patbry33
    Master:
  • 763 Answers
Sir have you tried to see your manual about this problem? after all the solutions and still the problem persist then you should send it to repair shop to replace some parts of this. hope that helps sir!
cheers
CHARCOIS
Posted on Sep 03, 2008
    Brigadier General:
  • 6,966 Answers
The scrambled error code is significant. This could possibly indicate a logic problem in the controller board. True that an error is present such as that the water is not filling, however, it is likewise likely that the control board itself is causing the intake water valves not to open.
As ginko pointed out, there is no such code but this does not mean that there is no error. It could be that part of the system that detects the error and eventually displays is is faulty, and were are back to the controller board. This is also probably the reason the system will not reset as proposed by onnieh49 though you can try it for a longer period, say 1 hour. Should you be interested, a listing of standard error codes for most Hotpoint machines may be found here.
perhaps it would be to your advantage to post back the exact model number of the Hotpoint Washing Machine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Genius:
  • 1,665 Answers
    Genius:
  • 2,920 Answers
Try unplugging the machine and then plug it back in after about 5 minutes
  • Hotpoint Master
  • 19,396 Answers
First try unplugging the machine.
Then try emptying the machine, unplugging and running a small load.
  • 3 more comments
  • Ginko
    Ginko Sep 03, 2008
    Then try emptying the machine, unplugging and running a smaller load.
    If this did not fix it then the machine it is probably faulty
    Start checking the power supply at the back, if water is not coming into the machine cycle will stop.
    Check that the drain hose is not obstructed.
    See if inlet valve is working and see if water is being poumped into the machine and drained during the cycle.
    Here are more hints from Repairclinic:
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's
    the timer, if your washing machine fills with water and begins
    agitating, but the timer never advances--or if the washer is in a spin
    cycle and the timer won't advance. Then you need to replace the timer.
  • It
    may be a cold-water supply problem, if the washing machine fills with
    water, agitates, drains, and spins, but then doesn't fill with rinse
    water. See There's no cold water.
  • Ginko
    Ginko Sep 03, 2008
    I cannot find error EE5E on Aquarius.
    Try to understand what the right error code is.
  • Ginko
    Ginko Sep 03, 2008
    there is no EE5E code as far as I know. If the error instead is F05, this means that the pressure switch is jammed or defective.
    This can happen because of a faulty or obstructed drain out pump.
    You access the pump removing the panel at the back of the washing machine at the base of machine. Once you get to the pump you unplug the two hose, remove the pump unplugging wires, and lifting the plastic block. Then you clean or replace the pump.
  • Ginko
    Ginko Sep 03, 2008
    If no water is coming it is probably a fault with the inlet valve, or with the cycler control.
    You need to test the inlet valve by energising it, if it does work fine you replace the control panel.
    If you have obstructed drain out pump instead, water does not come in as there is the error message, but machine stays filled with water and does not drain.
  • Ginko
    Ginko Sep 03, 2008
    Glad you fix it, as I said it was the pump.
    Next you use Fixya, why not to learn also how to use our rating system.
    Thanks for using Fixya.
    Hi I have model No WF 740 1400 spin! However programme L is filling up with water, appears to be washing as normal until it reaches final 7 minutes, then machine becomes laboured and will not spin! the...
    it appears that the pump is not removing the water that is spun out  if there is a belt on the pump then it may have fallen off or need replacing   if it is intact then the pump either failed or there is a blockage in the line
    Nov 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
    Testing Shows On Display
    press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
    Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
    Bearings very noisy on the drum
    aquarius w f 541 1400 spin drum bearing noisy
    Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
    Aquarise + super silent WF 630 1300 spin
    to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
    Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
    Hotpoint aquarius
    You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
    Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
    Hotpoint wf 250 aquaries
    try changing your water valve this should sort problem
    Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
    Does not spin and rinse properly
    Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
    Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
    Hotpoint ultima wt741
    washing machine WT741 ultima all light are flashing and it won't do anything else
    Nov 12, 2007 | Washing Machines
    Washing Machines Logo
    99 people viewed this question
    Top Hotpoint Washing Machines Experts
    hungoverrr
    Level 1 Expert
    puggy666
    Level 1 Expert
    gbob59
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
