Boot problem My pc is producing alot of noice on the processor fan and it is not booting, checked on processor, power supply and heat sink and they are ok
  • Ravel Lively
    Ravel Lively May 11, 2010
    Be a detective, exactly why do you think the processor, power supply and heat sink are okay? Saying so doesn't make it so!!!!!
    Scholar:
  • 141 Answers
Sounds like your CPU fan may be failing (bearings seizing), and that is either causing the CPU to overheat and shut down, or the fan may be drawing excessive power and causing power droops.
Posted on Sep 03, 2008
Heatsink
INSIDE A COMPUTER OR THE HEAT SINK FOR YOUR COMPAQ COMPUTER?
The "CPU" or central processing unit, otherwise known simply as "the processor," is the primary "brain" of the computer. Processors are very finely engineered components that are not repairable. But replacing a failed processor is an option for the owner of any model Compaq Presario desktop computer. Just check with HP/Compaq for the correct and speed of processor for your motherboard before purchasing a replacement.
Turn off the computer and disconnect all cables. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the cover. Lay the computer down flat. If there is a plastic hood covering an exhaust fan, remove it by pressing in on the indicated release tabs. Examine the processor assembly. The processor is a square chip that is covered by a metal heat sink with fins. A fan will often be mounted on top of the heat sink; unplug its connection to the motherboard. Two clips usually secure the heat sink assembly to the top of the processor. Gently press down and slightly away on the flat end of a clip to release it. Avoid using a screwdriver to release a clip; a slip could scratch the motherboard. Release the clips and gently remove the assembly. The heat sink should separate, leaving the processor behind in the chip holder. Clean the bottom of the heat sink. Use a paper towel and a dab of solvent cleaner to remove the old thermal paste. Set the clean heat sink aside. Lift up the lever to unlock the old processor and remove it from the pin mount. Insert the new processor chip. Align the pins on the processor to the "cut off corner" or dot on the pin mount. The processor should drop into the pin holes easily. If the processor won't drop in easily, check the pin alignment. Once the processor is inserted correctly, pull down the lever to lock in the chip. Apply thermal paste to the bottom of the heat sink. Apply enough paste to cover the area of the small gray rectangle on top of the processor. Apply the paste with a spreader made from a piece of flexible plastic. Spread the paste evenly to a thickness of two sheets of paper. Check the heat sink mounting alignment and lower the heat sink onto the top of the processor. Reinstall the mounting clips. Reattach the heat sink fan to the motherboard if necessary. Plug in the computer and monitor and boot. If the machine won't boot or it emits warning "beeps," unplug the power and monitor, and troubleshoot your work until the computer boots successfully. Shut down again and replace the exhaust fan hood. Close up the computer and reboot. Hope this helps.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=thermal+paste
Jan 19, 2013 | HP Compaq Presario SR5610F Desktop PC
Optiplex GX280 - loud fan at start up and amber power light - does not boot and no light at the back
Apply pressure on the heat sink fan right before you press the power button and continue applying pressure. Watch your screen if you see it boot this means its a problem with your processor clamp that applies pressure to the processor. Try to remove the top part of the clamp. Shouldn't be too hard with some needle nose pliers. Then just replace the heat sink and fan with out that clamp.
May 27, 2010 | Dell OptiPlex GX280 PC Desktop
My hp media center m7160n computer powers up, has a definite fan sound, normally the fan sound diminishes and the computer boots up. For the last several months, the high speed fan sound would not diminish...
How did you clean it?
The last one I worked on had the fins of the Heat sink totally blocked with dust. This will make the fan scream trying to push air thru the heat sink to cool the processor. If it isn't cooled it will shut down in short order.
You must BLOW it out. Use a pressurized air can. Better if you have a compressor with a nozzle.
The other issue may be the interface between the CPU and heat sink is defective. Heat sink moved or become loose.
Of course by this time the processor could be dead also.
May 17, 2010 | HP Computers & Internet
PC won't boot
processor may be heat up check it
  • Dust acting as a thermal insulator and impeding airflow, thereby reducing heat sink and fan performance.
  • Poor airflow including turbulence due to friction against impeding components, or improper orientation of fans, can reduce the amount of air flowing through a case and even create localised whirlpools of hot air in the case.
  • Poor heat transfer due to a lack of, or poor application of thermal compounds.
  • May 04, 2010 | Dell Latitude X200 Notebook
    I run the computer for about 30 min. sudenly it will stop showing anything in the monitor i try it to open but there is no boot and no picture , and i check even the processor heat sink is not produce heat
    hmm!! there is problem with your processor's heat sink only!!! your system is getting over heated so it shut downs automatically to prevent damage!! i have also gone through this problem!!! try changing the processor's fan!!
    Oct 24, 2009 | ASUS A8N-SLI Deluxe Motherboard
    I have a pc w/ asus k8v-mx mobo, the problem is it
    scan for virus, if it is not a virus change the power supply unit.
    Aug 14, 2009 | ASUS K8V-MX Motherboard
    Acer veriton M460 will not boot up
    The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
    Jul 31, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
    Computer won't boot up
    Check the heat sink connected on your processor and its cooling fan is working or not
    Apr 09, 2009 | HP COMPAQ Presario SR5410F Pentium...
    Computer hangs after 5 minutes from boot
    Check the CPU fan (working) and heat sink as these over time clog up with fluff and dirt overheating CPU also check the rear of power supply for blocked ventilation holes
    Jul 20, 2008 | Intel Pentium 4 1.7G, 1.7 GHz...
    Computers & Internet Logo
    57 people viewed this question
    David Payne
    David Payne
