Question about Fuji FinePix S5200 / S5600 Digital Camera
Time exposure shot
Can a long exposure shot be taken with this camera? Help! Second hand with no instruction manual. Thanks, Fran
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
FinePix S5200
The max exposure time is 15 seconds. See page 42:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 03, 2008
Can I manually adjust exposure and ISO on this camera?
Your camera is capable of full manual control once you turn the mode dial to "M". Your instruction manual should explain everything.
Jun 08, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony DSC H-5 Camera slow response time
you might have switched the shooting process to timer mode. please refer the instruction manual to change it back to normal mode.normally there will be button near the lcd screen with the symbol of a timer deviice. if you click it once it sets the delay of shot to 2 sec and for the second time to 10 secs.and for the third time, it goes back to normal mode. thanks for using fixya. please dont forget to rate my solution!!!
May 29, 2009 | Cameras
Using timer
Kodak EasyShare C613
Changing picture-taking settings
You can change settings to get the best results from your camera.
1Press the Menu button.
2Press to highlight a setting, then press OK.
3Choose an option, then press OK.
■Press the Menu button to exit the menu.
NOTE: To better understand each menu option, use camera Help. Highlight a menu choice, then press the button. Some settings remain until you change them; others, until you change modes or turn off the camera. Some modes offer limited settings.Press Menu, , and OK to access settings
Options
Self-timer
10 seconds (default)—
so you have time to get into the scene.
2 seconds—
for a steady, auto-shutter release on a tripod.
2-shot—
one picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
Exposure Compensation
Increase or decrease brightness before taking a picture. (Also see page 27.)
0.0, -0.5, -1.0, -1.5, -2.0, +0.5, +1.0, +1.5, +2.0
From: http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00711/C613_UG_GLB_en.pdf
If this helps, please post a rating for me. Thanks!
OpenSource13
Apr 19, 2009 | Kodak EasyShare C613 Digital Camera
Night and low-light specialty/experimental photography
Hello, thanks for the compliments!
First, yes, the Digital Rebel series of cameras (my first DSLR was the first Digital Rebel, the 300D model) have a small sensor than a "full frame" sensor, which results in a "multiplicationfactor" or "crop factor" of .6. This is good for telephoto shots (yourtelephoto lens ends up acting like a "longer" and more expensive lens) but bad for wideangle shots.
For Macro, you need very bright light to have enough light to use a small fstop for needed DoF because even at the smallest fstop (largest number) your DoF will still be very small. This typically means you need to use a strobe. The strobe will help freeze the image so you can still shoot hand-held. For hand-held use look for a "ring strobe" that fits around your lens and lights the item in front of your lens.
Focusing is a very tricky matter when you are shooting in macro. Usually you go to manual focus, set the lens to manually focus at either infinity or the closest distance, then you "focus" using the zoom, rather than the focus ring.
For night shots, you need to change to manual exposure and adjust to get the exposure you desire. Your camera's light meter doesn't know how bright or dark the thing you are viewing is - to the light meter everything you point it at is supposed to be exposed to medium gray - an average value. It can't know that you want a dark shot to stay dark.
Here's how I do it. First, I bump up the ISO so I can take a fast shot, and I set the camera to AV mode. Then I set the lens to the widest aperture (smallest number). I let the camera set the shutter speed as I take this test shot, and look at the exposure. Then I determine if I want the shot darker and if so how much. Now I switch to manual mode - same aperture and shutter as the previous shot, and adjust the shutter speed faster to produce a darker image. When I have the right settings, then I adjust the ISO and as I adjust the ISO I have to compensate with the shutter. E.g. if I have a good exposure at ISO 1600 @ f2.8 @ 1/30, to drop to ISO 100 means I have to slow the shutter to 1/2 second. Now, I usually also want a smaller aperture (larger number). To go from ISO 100 @ f2/8 @ 1/2 second to f/16 is 6 stops, which takes the time needed from 1/2 second to 15 seconds. Obviously this means the camera needs to be on a tripod.
I can help more if you can give me a link to some of the photos you have taken so far so I can see what you are shooting, and make suggestions for how I would approach the same subject and situation.
Dec 15, 2008 | Canon EOS Rebel XSi Digital Camera
Shots taken
It is useful for the pro to know the settings automatically at every exposure.But if you dont like you can avoid it by going through the menu.You select "No" to display info or preview
Mar 11, 2008 | Nikon D40x Digital Camera
Extremely long time writing to CF card
IIRC these cameras support a noise reduction feature through a custom function. The camera will take a second exposure with the shutter closed (i.e. against something pure black) to see which pixels in the camera are "hot", and then will use that information to remove that hot pixel noise from the original image. "hot" pixels depend on temperature and exposure length so the camera would need to do this on every shot.
Mar 05, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Taking a photo of the family, delaying the camera until I can get into the shot.
Sure, follow these steps...
  • Set everyone in an even composition, close together, maybe some standing, some sitting, whatever strikes you as a good picture.
  • Put the camera on a tripod or other tall article
  • Press the Mountain/Macro/Timer button until the (clock/timer) icon is displayed on the viewer. The button to press is just above the MF (Manual Focus letters)
  • Press the shutter button all the way down to activate the timer.
    • Press once for ten-second delay
    • Press twice for three-second delay
    • Press a third time to stop the timer
  • Jump into the shot! =)
The lamp next to the lens will start to blink and continue until one second before the picture is taken. The lamp will then stay solid during the last second to warn about the picture being taken.
Please rate FixYa!, ThankYa!
Dec 15, 2007 | Nikon Coolpix 4500 Digital Camera
Blinking hand and exclamation point- less focus
It's a vibration indicator. My camera has just begun doing it too. It's on P.17 of the manual.
Oct 23, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Fuji FinePix S5200 / S5600 Digital Camera Logo
198 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
