Phillips 32" LCD TV, locked into "digital" mode and no signal, blue screen only. Originally is worked in both modes, then digital signal vanished to blue screen only (including no menu options), then finally on trying it again it has now locked into digital mode, and the 5 second menu button does not hard reset it, neither does powering down and or removing the mains for several minutes. This TV is about 15 months old and had a 12 month warranty!!
SOURCE: Acer AT3201W 32 in. LCD Television
I have exactly the same problem, my unit has been sent to the service centre 3 times already and they still haven't fixed it. It appears to be a main board issue. I will send it back again for servicing and will NOT take it back unless the main board is replaced.
Posted on Aug 09, 2007
SOURCE: TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Posted on Oct 31, 2007
  • 1694 Answers
SOURCE: Mitsubishi WS65513 with blinking green light
Download Chris@ChrisAndNat.com .........T.
Posted on Nov 09, 2007
Adolph
  • 137 Answers
SOURCE: Blue screen for a second after power on and then black screen again
Check where your plug go's in to your powersupply if it is well fitted. ////sometimes it dosnt make well connection then you will struggle to get it on.
Posted on Dec 22, 2007
SOURCE: RCA HD50LPW62AYX2 WILL NOT STAY ON
My HD50LPW62AYX2 RCA TV sometimes reverses the blue and reds. The peoples faces are blue, especially the lips.
Sometimes turning the TV off and then back on again fixes the problem. At other times this correction is good for only a second or two.
Do you have an English owner's manual available on line or otherwise available?
Posted on Mar 05, 2008
Lcd tv goes blue screen
Blue Screen usually means you have no video source, but also it can be a bad cable, bad signal, or week signal. I will try to hook it up to a dvd and test it on another source. However the screen should be all blue aand not blue lines, if you can email me a photo of the screen I will be able to properly address it.
Tony Mitri
goldtekfl@hotmail.com
Feb 15, 2014 | APEX Digital Inc. Apex Digital 32" 720p...
Emerson LC320EMX stays in standyby mode
one of the transformers has an issue which is very common for that model. You can get a replacement inverter from www.tvrepairworld.com
Mar 31, 2012 | Emerson LC320EMX 32 in. LCD HDTV
Having trouble with my LTV-32HBG only has a blue screen and says no signal .
It might be something really simply - you may have changed from Analogue TV mode to Digital TV mode or vice-versa.
Press the DTV/ATV button on your remote, which is just below the "MUTE" button in the top right-hand corner.
If that doesn't work, please let me know whether you are using a cable box, satellite receiver or whether your TV is just connected to an antenna and we can try some other options.
Regards,
BElectric
Nov 30, 2010 | Astar LTV-32HBG 32 in. LCD Television
TV screen reading no signal. We have satellite
tune in tv or put tv in AV / EXT mode the no signal means not tuned or on areal in tv
Nov 28, 2009 | Sony Televison & Video
My Phillips SLC4 flat screen TV has suddenly
The problem has cleared itself a day later after being switched on/off a few times.I suspect the 'computer part' of the TV (channel processor, instruction decoder etc) received maybe a power glitch or an illegal infrared instruction (2 remotes used at once for example) and 'locked up' leaving just the analogue side operating.
I was going to continue happily using it with just the analogue side slaved to my Hd recorder for digital signals but it seems to have got over whatever it was that upset it.
Sep 07, 2009 | Philips Televison & Video
Vizio LCD DTV 32 inch. Model L32. I can't 'scan' for digital channels. When I go to DTV, then Menu and scroll right or left to "TV tuner setup' I get a blue screen and nothing else. No key on the...
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Mar 23, 2009 | Vizio L32 32 in. LCD HDTV
CANT USE DIGITAL TV OR HDMI MODE - SCREEN NOT SIZED
Give FUNAI a call they can walk you through the problem. There info is...
FUNAI CORPORATION Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
Feb 15, 2009 | iLO IWT3206 TV
Weak or no Signal issue when connected to my TV.
Yes weak signal. Also closing the laptop lid puts the computer in sleep mode.
Jul 07, 2017 | Digital Lifestyle FA1B32Z 32 in. LCD...
Cannt get tv to change chanel
Check the mode the tv is on (Use "Source" button on remote to change modes). There are several modes to choose from.
Jul 16, 2008 | Akai LCT3201AD 32 in. LCD Television
Tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
Sep 17, 2007 | Sanyo DP26746 26 in. LCD Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
