when computer is swiched on screen will not move of acer screen,it instucts me to press f12 to boot my pc but nothing happens i have tried 3/4 differant key boards,lights on keyboard flash once when computer is switched on.
Comments:
Sep 05, 2008
- no when i press f12 it does not go in to bios screen,that is the problem, i am trying to install windows xp
when you hit F12.... does it enter the bios setup screen ?
Robert
Same Problem
May 19, 2009
-   cant go beyond acer screen, with press del or F12 , nothing responds, same as others have writtne , will not go to setup or menu -   Guest
May 18, 2009
-   Sticks at ACER white screen with Hit Del or F12 but will go no further-   Guest
Mar 11, 2009
-   i have exactly the same problem. mine did this after i felt a static discharge while connecting a usb device. i am assuming the mobo/cpu or something in the power supply got fried.
-   alasdairm
ok fair enough.... boot the computer and watch the screen.... you need to watch for the key to enter setup.... delete key seems to be the most popular but i've had computers use f1 and f2, f11 and f12.... if it goes to fast hit pause as it gets to the point where it tells you the key to hit to enter setup.... after you are in change the boot sequence to boot to cdrom..... hit f10 and save the changes... reboot to the cd and continue with your install
I had tried to flash my Gb-k8vt800m board using @Bios and got a bootblock lock up. I had saved the...
(More)
I had tried to flash my Gb-k8vt800m board using @Bios and got a bootblock lock up. I had saved the original bios to a file on my desktop prior. I now have that hard drive as a slave in second identical board (wifes), and same identical computer and can see the new hard drives but, Can I restore the bios to the slave drive and use it as a master? It will only boot as a slave if I install it as a master the system wont boot. Regards, Alan moneyisbetter.com
Please can you help with my old machine with motherboard, the brand is PC CHIPS M863G V5.1. ALL DVD...
(More)
Please can you help with my old machine with motherboard, the brand is PC CHIPS M863G V5.1. ALL DVD THAT I TRIE INSTALL NOT WORK, I AM USING WINDOWS VISTA PREMIUM AND THE SYSTEM CAN SEE IN ENVIRONMENT D.O.S BUT THE UNTIL START WINDOWS, BUT NO WORK, WHEN START WINDOWS NO FOUND NOTHING OF DVD. THE BRAND OF MY DVD/RW IS LG-MODEL: GSA-HA0A. THANK VERY MUCH. SORRY TO MY ENGLISH AND I HOPE THAT YOU UNDESTAND.
My computer with Syntax SV400 mother board will boot sometimes, sometimes will not do an automatic...
(More)
My computer with Syntax SV400 mother board will boot sometimes, sometimes will not do an automatic reboot when loading drivers and sometimes nothing happens when I turn the power on
