Question about NEC MobilePro 900 Handheld
Identify the serial number
How do I identify the serial number on the MobilePro 900?
    Master:
  • 903 Answers
The NEC serial number is located on the Device Rating Label (DRL) and is clearly marked. The DRL label has the UL, FCC and NEC in bold type face and is located directly below the CAUTION sticker on the bottom side of the unit.
Posted on Sep 14, 2005
SOURCE:
What is the serial number on a mini Rae 3000 for.
Hello, Jeff -
A serial number for ANY series of a manufactured item identifies each individual item. A serial number can be just numbers or a combination of numbers and letters. Each serial number is unique.
https://en.wikipedia.org/wiki/Serial_code
(Quote)
Serial numbers identify otherwise identical individual units with many, obvious uses. Serial numbers are a deterrent against theft and counterfeit products, as they can be recorded, and stolen or otherwise irregular goods can be identified.
(End quote)
Therefore, the serial number on a Mini RAE identifies that particular hand held volatile organic compound monitor.
Best wishes.
May 08, 2018 | The Computers & Internet
What year is my schwinn FB08291
Congrats! Your bike is an original Chicago Schwinn.
Built: JUNE of 1966 Search Results
Schwinn serial number lookup tool
schwinncruisers.com/serial-number.html This tool searches a database of Schwinn serial numbers and if it finds a ... box and click "find" to see what date and year your Schwinn bike was manufactured.
Schwinn Serial Numbers and Date Codes - Re-Cycle
re-cycle.com/History/Schwinn/SwnB_Serial.aspx All serial number records before 8/18/1948 were lost in a factory fire. ... If you have a Schwinn from this era, please, PLEASE send us pictures of your bike and serial number (Cutter@Re-Cycle.com). We are in the process of collecting pre-1948 serial numbers in the hopes of rebuilding ...
THE SCHWINN DATE CODES BY YEAR,MONTH AND DAY - Angelfire
www.angelfire.com/rant/allday101/SchwinnCodes1.html/ THIS CHART APPLIES TO CHICAGO SCHWINN`S ONLY. SCROLL DOWN FOR THE DATE CODES LINKS BY FRAME LOCATION OF THE SERIAL NUMBER.
How to Identify a Schwinn Bicycle ' Gone Outdoors ' Your Adventure ...
goneoutdoors.com/identify-schwinn-bicycle-6115826.html Schwinn bicycles are easy to identify by the Schwinn logo displayed on the bike. ... Johnson Outboard Identification · What Is the Difference Between a Schwinn ...
Schwinn serial number result
Jun 18, 2017 | Schwinn Cycling
Hard reset???
Warning: This procedure will ERASE all user data stored on the MobilePro 900. Make sure you have backed up all data before doing the following. To hard reset your MobilePro 900, simply remove both the main and back up batteries for 60 seconds. For detailed instructions on performing a hard-reset: http://support.necsam.com/mobilesolutions/hardware/Handhelds/MobilePro900/819-201025-000.pdf
Sep 14, 2005 | NEC MobilePro 900 Handheld
32-bit card bus PCMCIA
No. The MobilePro 900 PCMCIA slot only supports 16-bit PCMCIA (PC Card) cards.
Obtain the USB drivers
You can obtain them from the Apps and Driver CD that was shipped with the device or download them here: Windows XP USB: ftp://ftp.necsam.com/pub/MobilePro/900/WinXP_MP90-USB.exe Windows 2000 USB: ftp://ftp.necsam.com/pub/MobilePro/900/Win2k_MP90-USB.exe
Turn off the modem speaker
To mute the MobilePro 900’s speaker volume, do the following: NOTE: This procedure will have to be performed for all existing and future dial-up connections. * 1. Open Remote Networking by tapping “Start” ? “Programs” ? “Communications” ? “Remote Networking.” * 2. Highlight your dialup connection by tapping it once. Tap “File” ? “Properties.” * 3. Tap the "Configure" button. * 4. Tap the "Call Options" tab. * 5. Enter "M0" in the "Extra Settings" box. (This is capital letter followed by the number zero without any spaces or quotation marks.) * 6. Tap “OK” to close the device properties window. * 7. Tap “Next” and then “Finish” to complete the Dial-up Connection wizard.
Ctrl+ALT+Del does not launch Task Manager on my MobilePro 900, why?
The Ctrl-alt-del short cut to the Task Manager is not on the MobilePro 900. To bring up Task Manager on the MobilePro 900, hold the "Alt" key and then tap the task bar with the stylus simultaneously. A menu with "Task Manager" and "Properties" will be displayed, select Task Manager.
"Backup Battery Very Low"
NEC has identified an issue where the system can erroneously generate the "Backup Battery Very Low" message. There are two possible solutions that will eliminate this erroneous low battery warning message (the first method is the preferred solution, the second method can be used if the update file is not available). Solution I. Install a new version of the driver that controls the battery monitoring circuit. 1. Download the Low battery warning fix to your desktop. 2. Using ActiveSync or a compact Flash Card, copy FixBatt_HPC2K.EXE to the MobilePro internal disk. 3. On the MobilePro, double click the FixBatt_HPC2K icon. 4. When the message "Low Backup Battery Issue" is displayed, tap the "Patch it" button 5. When prompted turn unit over and momentarily depress the Reset button using the stylus. Solution II. Change the default power management configuration. Configure your MobilePro 900 to suspend when the LCD lid is closed on battery power and AC power. To ensure that the device suspends whenever the lid is closed, please make the following changes and perform a soft reset: 1. Go to Control Panel. 2. Open MobilePro Settings. 3. Go to the LCD Suspend/Resume tab. 4. Place a check next to "Enable suspend while on External Power." 5. Click the "Advanced" button and place a check next to "Enable suspend while on External power. 6. Click OK to close the Advanced Setting window and click OK to close the MobilePro Settings. 7. Turn unit over and momentarily depress the Reset button using the stylus. NOTE: Both the software update and power management settings are cleared on a hard reset and must be re-applied.
32 bit cardbus/PCMCIA card
The MobilePro 900 does not support 32 bit card bus devices.
Jack for the external microphone
There is an error in the MobilePro 900 manual (Pages 2-2 and 2-3). The jack on the front of the MobilePro 900 is a stereo headphone jack only. The MobilePro 900 has a built in microphone. There is no jack for attaching an external microphone.
NEC MobilePro 900 Handheld Logo
328 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
