The speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
or you might have to clean
the dust from your computer dust causes static which causes your computer to
overheat and all sorts of problems
be sure to wear an anti
static earth strap before touching anything inside your computer try
cleaning your computer of dust using a fine air blower from a compressor making
VERY sure that there is no MOISTURE in the air line specifically around the CPU
central processing unit and your SOUND CARD dust causes static to build up in a
computer causing it to overheat any many other problems
hope this helps
