Question about Intel D845GBV (BOXD845GBVL) Motherboard
Hanging computer as soon as i start my computer it shows a message" YOUR COMPUTER HAS BEEN SHUT DOWN DUE TO A THERMAL EVENT. PLEASE REPLACE THE UNIT" which unit should i replace.
    Brigadier General:
  • 5,158 Answers
Check the cpu fan when you start the computer... does it turn. if not replace it.
Posted on Sep 08, 2008
Thermal event won't ever allow computer to boot at all
"Computer unplugged from power, press the Power On button in, and hold it in. Hold it in for a count of 10 seconds. let go. Do this procedure two more times. (If the Power On LED lights up, do it again) What you are doing is clearing CMOS Error Codes. Check the Processor fan, check the Thermal Paste. Cheap as Thermal Paste is, and what it does for a job, best advice is to simply replace it. Need guidance post back in a Comment. Before beginning make sure the computer is unplugged from power, and you are FOLLOWING Anti-Static Precautions. Regards, joecoolvette"
Brian Packard;
"I cleared CMOS a few times (has jumper on board too) and even put new thermal grese on it....what finally did it was taking out the CMOS battery. As long as it's outl it works just fine, putting it back in causes an error again. Thank you all for your time however and I hope this post can help somebody else too."
Aug 20, 2012 | Gateway 507GR PC Desktop
What will i do with my cpu hanging while it boots... it completely freezes and all i can do is do a hard shut down... and, it wouldnt boot after power off.. specs mboard.. xfs xg31i processor.. dual...
When your cpu does not load completely it is usually caused by problems from the system files therefore making the unit not to load. The OS on your unit could either be corrupted or be lacking in some system files. To solve this simply get the OS disc and run it on your unit. Just like trying to format but instead of formatting run a repair for the system. This should replace the corrupted files or missing ones.
Hope this solution has been helpful?
May 25, 2011 | Computers & Internet
HI I have a D865 PERL m/b. The CPU overheated, due to a load of dust blocking the heatsink fins. I have cleaned it all up and the heatsink should be fine now, but when I try and boot I get a message...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 14, 2011 | Intel D865PERL Motherboard
Respected Sir, When I was working on my computer, suddenly the CPU has been put off. I put on it again. It says that my pc had shut down due to thermal event (over heating). When I...
just place your computer in a well ventilated area. if possible add new fans for your pc.. if it is a laptop add an external fan...
dont forget to rate!
Jan 23, 2011 | Computers & Internet
Keep getting a message that says cpu shut down due to thermal event and when i reboot i hear 3 beeps
If you are looking at the pc from the front, take the left side cover off and ensure that the fan on the cpu is spinning when you turn the machine on. If it isn't, that needs to be replaced. If it is working, shut the pc completely down. Grasp the fan and heat sink unit and ensure that it does not move or wiggle at all. If it's loose, tighten the screws holding the fan/heatsink unit down. Try that and reply back with your findings.
Good Luck,
Aug 18, 2010 | E-Machines eMachines Desktop PC
Every time i start the pc there is a thermal error message the sound of three beeps then shut down unless pc is left off 48 hours error message.
Thermal event are serious, (too hot) make certain of your fan/fans are working. Clean out the dust that has accumulated. Use you computer in a cool environment if possible. If the error continues, purchase some Arctic 5 ceramic paste take off your heat sync apply a very thin coat to the bottom of the heat sync (after you clean it of course) replace the heat sync.
Also pull out the ram (memory) and reseat it.
This should take care of it. If not please ask again.
Please leave a rating...
May 15, 2009 | Dell Dimension 3000 PC Desktop
PC gets shut down
this means that it is overheating. you can do many things here. 1. take off the CPU cooler, and reapply some heatsync and see if that fixes the problem. 2. buy a larger, or more efficient CPU cooler, is a great place to find good parts that are cheap and come with customer reviews already. 3. change the settings in your bios to allow the CPU to become warmer (do not go above 75 degrees) without shutdown or alarm.
Jan 06, 2008 | Audio Players & Recorders
Mistankenly i connect config jumper on fan connecctor
Try resetting the BIOS to default,and see if it clears the error.
let me know if this works.
Dec 12, 2007 | Intel D945GNT Motherboard
Open Questions:
Intel D845GBV (BOXD845GBVL) Motherboard Logo
71 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
